Chassis Q: Diagnol vs. Wishbone #2986218
11/17/21 09:03 PM
11/17/21 09:03 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
At what ET do you go to a Wish bone in?
Just curious, when does it really help? Is it for hard leaving cars or what determines when to switch?
Re: Chassis Q: Diagnol vs. Wishbone [Re: Dragula] #2986274
11/17/21 11:43 PM
11/17/21 11:43 PM
My Duster and S/P Cuda both have diagonal links and anti sway bars.
The Duster went 10.00 at 134.+ MPH on ET Street tires ladder bar and coil overs with the diagonal link, steady as a Lincoln on the street and strip up
The Cuda has gone 8.86 at 150.+ MPH with no issues, it goes straight as a bullet, unless it spins on the line. 4 link with coil overs and diagonal link and anti sway bar mounted behind the Dana 60 up
Re: Chassis Q: Diagnol vs. Wishbone [Re: Cab_Burge] #2986326
11/18/21 08:10 AM
11/18/21 08:10 AM
Dragula Offline OP
Dragula  Offline OP
Ohhhhkay.......I do know the radial cars need to have them. My car runs 9.40's....And it runs pretty straight even when it breaks the big tires loose. Just wondering though, if there might be some gain in the 60ft with a wishbone.
Re: Chassis Q: Diagnol vs. Wishbone [Re: Dragula] #2986327
11/18/21 08:19 AM
11/18/21 08:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine runs mid 1.2x 60ft @3325 using a diagonal link. Has 750 passes on it. Never bent anything. Changed the rod ends at 725 passes but they were not loose.
Doug
Re: Chassis Q: Diagnol vs. Wishbone [Re: dvw] #2986379
11/18/21 12:18 PM
11/18/21 12:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Warren Johnson ran a diagonal link in Pro Stock...I am good friends with Gary Hanson he loves telling that story about Warren getting cars and removing the wishbone. Gary owns his own chassis shop and ran Pro Stock for a long time. He will install wishbones but prefers a diagonal link. Thye both do the same job.
I have run high 7's with a Diagonal link with a 4 link and the Vette runs 7's with a diagonal link and ladder bars. Been 1.07 60' with one.
Re: Chassis Q: Diagnol vs. Wishbone [Re: Cab_Burge] #2986403
11/18/21 01:00 PM
11/18/21 01:00 PM
moparx Offline
moparx  Offline
Cab, do you have [or anyone else for that matter] any pics of your sway bar and mounts ?
beer
Re: Chassis Q: Diagnol vs. Wishbone [Re: moparx] #2986419
11/18/21 01:35 PM
11/18/21 01:35 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
the only issue I have seen with Diagonal links is if they are under sized.. . the longer they get the bigger around they need to be. They will bend if too small a dia on hard leaving cars and in situations where the car gets out of shape.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Chassis Q: Diagnol vs. Wishbone [Re: W.I.N. Racing] #2986439
11/18/21 02:16 PM
11/18/21 02:16 PM
Marysville Wa
moparfan Offline
moparfan  Offline
Marysville Wa
My car has been 7.06 @ 195 with 1.02 60' with a diagonal link
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Chassis Q: Diagnol vs. Wishbone [Re: moparx] #2986461
11/18/21 03:38 PM
11/18/21 03:38 PM
beer
Not that I know of, sorry.
BTW, the Duster did NOT have a anti sway bar, sorry. blush
Re: Chassis Q: Diagnol vs. Wishbone [Re: Cab_Burge] #2986476
11/18/21 04:23 PM
11/18/21 04:23 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I would go wishbone. No reason not to.
2011 Drag Pak Challenger
Re: Chassis Q: Diagnol vs. Wishbone [Re: Cab_Burge] #2986477
11/18/21 04:25 PM
11/18/21 04:25 PM
Dragula Offline OP
Dragula  Offline OP
I have a sway bar in mine....I would not do a 4-link without one.
Re: Chassis Q: Diagnol vs. Wishbone [Re: rickseeman] #2986501
11/18/21 06:17 PM
11/18/21 06:17 PM
The diagonal link on ladder bars with coil overs works good, especially on the street up boogie scope twocents
Re: Chassis Q: Diagnol vs. Wishbone [Re: Cab_Burge] #2986517
11/18/21 06:47 PM
11/18/21 06:47 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I used the WB only backwards, pivot on the housing, The Y part at the front of lower bar mounts on 4 link. I didn’t want a broken u-joint dropping the shaft into either.
Re: Chassis Q: Diagnol vs. Wishbone [Re: cudaman1969] #2986538
11/18/21 07:37 PM
11/18/21 07:37 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
My SC/SG friend runs X links, they moved away from wishbones. It's throttle stop stuff though so I'm not sure how applicable it is to door cars.
Re: Chassis Q: Diagnol vs. Wishbone [Re: Blusmbl] #2986614
11/18/21 10:22 PM
11/18/21 10:22 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Is the preference of the diagonal link because of the weight reduction? Or because it functions better? I imagine a wishbone being heavier and requiring more maintenance.
Alan Jones
Re: Chassis Q: Diagnol vs. Wishbone [Re: LA360] #2986646
11/19/21 01:01 AM
11/19/21 01:01 AM
Most of the better chassis shops in SO CA years ago told me to use the KISS principle on all race cars. up AKA as "Keep It Simple, Stupid" up boogie
Works good, lasts a long time boogie up
Re: Chassis Q: Diagnol vs. Wishbone [Re: Dragula] #2986900
11/19/21 05:17 PM
11/19/21 05:17 PM
moparx Offline
moparx  Offline
Dragula, that pic was exactly the example i was looking for. Thank You Sir ! up bow
beer
Re: Chassis Q: Diagnol vs. Wishbone [Re: W.I.N. Racing] #2986901
11/19/21 05:19 PM
11/19/21 05:19 PM
moparx Offline
moparx  Offline
Originally Posted by W.I.N. racing
the only issue I have seen with Diagnol links is if they are under sized.. . the longer they get the bigger around they need to be. They will bend if too small a dia on hard leaving cars and in situations where the car gets out of shape.
WIN, what would you consider under size ?
beer
Re: Chassis Q: Diagnol vs. Wishbone [Re: Al_Alguire] #2987510
11/21/21 02:42 PM
11/21/21 02:42 PM
Texas
Chief Offline
Chief  Offline
Texas
^^^ Agree.
I had a wishbone. At the time I thought they were the way to go. Changed my mind when I discovered how much wear the slip joint incurred. Car was unstable. Switched to large diameter 1 1/4 diagonal and could not believe the difference. Car ran 4.70. 1.04 60".
Dave Covey
Re: Chassis Q: Diagnol vs. Wishbone [Re: Chief] #2988038
11/22/21 09:51 PM
11/22/21 09:51 PM
Superfreak
Superfreak
What is the consensus on an x bar?
