Chassis Q: Diagnol vs. Wishbone
#2986218
11/17/21 09:03 PM
11/17/21 09:03 PM
Posts: 12,392 Taxes & Virus's R-US, NY
Dragula
At what ET do you go to a Wish bone in?
Just curious, when does it really help? Is it for hard leaving cars or what determines when to switch?
Re: Chassis Q: Diagnol vs. Wishbone
[Re: Dragula]
#2986274
11/17/21 11:43 PM
11/17/21 11:43 PM
Posts: 43,202 Bend,OR USA
Cab_Burge
My Duster and S/P Cuda both have diagonal links and anti sway bars. The Duster went 10.00 at 134.+ MPH on ET Street tires ladder bar and coil overs with the diagonal link, steady as a Lincoln on the street and strip The Cuda has gone 8.86 at 150.+ MPH with no issues, it goes straight as a bullet, unless it spins on the line. 4 link with coil overs and diagonal link and anti sway bar mounted behind the Dana 60
[Re: Dragula]
#2986327
11/18/21 08:19 AM
11/18/21 08:19 AM
Posts: 9,843 MI, usa
dvw
MI, usa
Mine runs mid 1.2x 60ft @3325 using a diagonal link. Has 750 passes on it. Never bent anything. Changed the rod ends at 725 passes but they were not loose. Doug
[Re: dvw]
#2986379
11/18/21 12:18 PM
11/18/21 12:18 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Warren Johnson ran a diagonal link in Pro Stock...I am good friends with Gary Hanson he loves telling that story about Warren getting cars and removing the wishbone. Gary owns his own chassis shop and ran Pro Stock for a long time. He will install wishbones but prefers a diagonal link. Thye both do the same job.
I have run high 7's with a Diagonal link with a 4 link and the Vette runs 7's with a diagonal link and ladder bars. Been 1.07 60' with one.
[Re: moparx]
#2986419
11/18/21 01:35 PM
11/18/21 01:35 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
the only issue I have seen with Diagonal links is if they are under sized.. . the longer they get the bigger around they need to be. They will bend if too small a dia on hard leaving cars and in situations where the car gets out of shape.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2986439
11/18/21 02:16 PM
11/18/21 02:16 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
My car has been 7.06 @ 195 with 1.02 60' with a diagonal link
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: moparx]
#2986461
11/18/21 03:38 PM
11/18/21 03:38 PM
Cab_Burge
Cab, do you have [or anyone else for that matter] any pics of your sway bar and mounts ? Not that I know of, sorry. BTW, the Duster did NOT have a anti sway bar, sorry.
[Re: cudaman1969]
#2986538
11/18/21 07:37 PM
11/18/21 07:37 PM
Posts: 8,165 Plymouth, MI
Blusmbl
Plymouth, MI
My SC/SG friend runs X links, they moved away from wishbones. It's throttle stop stuff though so I'm not sure how applicable it is to door cars.
[Re: Blusmbl]
#2986614
11/18/21 10:22 PM
11/18/21 10:22 PM
Posts: 6,142 Melbourne , Australia
LA360
Is the preference of the diagonal link because of the weight reduction? Or because it functions better? I imagine a wishbone being heavier and requiring more maintenance.
Alan Jones
[Re: Al_Alguire]
#2987510
11/21/21 02:42 PM
11/21/21 02:42 PM
Posts: 201 Texas
Chief
Texas
I have run high 7's with a Diagonal link with a 4 link and the Vette runs 7's with a diagonal link and ladder bars. Been 1.07 60' with one. ^^^ Agree. I had a wishbone. At the time I thought they were the way to go. Changed my mind when I discovered how much wear the slip joint incurred. Car was unstable. Switched to large diameter 1 1/4 diagonal and could not believe the difference. Car ran 4.70. 1.04 60". Dave
Dave Covey
[Re: Chief]
#2988038
11/22/21 09:51 PM
11/22/21 09:51 PM
Superfreak
Superfreak
What is the consensus on an x bar?
