Re: 750 Holley doesn't get fuel to the bowl
[Re: CudaMan]
#2985509
11/15/21 05:52 PM
11/15/21 05:52 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Needle and seat is stuck, and/or float is stuck.
Take the lock screw off, turn the nut CCW until the needle and seat assy comes out. If the needle moves freely and isn't stuck in place, then the bowl will have to come off to investigate further.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2985517
11/15/21 06:33 PM
11/15/21 06:33 PM
Posts: 20,207 Park Forest, IL
slantzilla
Park Forest, IL
Does it have the bronze filters in the fuel inlets? I just installed a 3310 on a buddy's truck that had them.
[Re: B1MAXX]
#2985915
11/16/21 09:56 PM
11/16/21 09:56 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
Get a small funnel, or squirt bottle and fill the bowls through the vent tubes/holes. It takes forever, for a dry system to get fuel up to the carb. You might have to do it a couple times. UHHH No From the OP: When I crack the fuel valve seat lock screw fuel is squirting out.
[Re: ZIPPY]
#2986194
11/17/21 07:47 PM
11/17/21 07:47 PM
Posts: 57 St George, UT
CudaMan
St George, UT
I pulled the needle and seat and found the needle to be stuck. I cleaned it and lubed it a bit and put it back. Still no fuel. I checked the fuel pump once more just for fun and found it was not pumping fuel. Off to exchange it for a new one. Thank you for the needle check idea as well as the other suggestions on the sticky floats. I will update the post with a running 440, (unless the next new fuel pump is poop....)
