833 od or non? #2985379
11/15/21 12:17 PM
11/15/21 12:17 PM
oregon
greendart408 Offline OP
oregon
I have a 75 I think all iron case 833 here, a body tail housing. Can somebody tell me by the vin what it was? I’m looking for a 74-5 318, non OD 833 so I can put the low gear guts in my street strip ride for et gain. Thanks in advance
Re: 833 od or non? [Re: greendart408] #2985411
11/15/21 02:04 PM
11/15/21 02:04 PM
A727Tflite Offline
A727Tflite  Offline
Unless you know the thing has not been modified why don’t you just check the gear ratios on the bench.
Re: 833 od or non? [Re: A727Tflite] #2985421
11/15/21 02:15 PM
11/15/21 02:15 PM
iagree scope
Put a mark on the input shaft and throw out bearing collar and a front drive shaft yoke and mark it and the tail shaft, put it in 1st gear and rotate the input shaft and count the revolution it takes to make the drive shaft yoke one full revolution scope wrench up
Same thing for any gear you want to know the ratio, a 2.66 low gear should rotate 2 full revolutions and a little more than 1/2 revolution scope
The over drive trannys in O.D. gear will rotate 1 1/4 full turns, if I'm remembering correctly work
Re: 833 od or non? [Re: greendart408] #2985426
11/15/21 02:19 PM
11/15/21 02:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"G" is the plant code for St. Louis which built Dodge Dart/Plymouth Valiant cars from '73-'76. I believe 6-cylinder cars got the non-OD trans and V-8's got the OD.
I agree, why not just shift into 1st gear and count the turns?
Re: 833 od or non? [Re: John_Kunkel] #2985445
11/15/21 02:38 PM
11/15/21 02:38 PM
oregon
oregon
I did that and it's 3.09 1st. My confusion is in 3,4th and with the lever needing to be up or down with a od and non. One gear is 1:1 and the other turns the output around 1.35 ish. So I must be a OD unit? Disregarding the lever orientation that's what I get when turning the input 1 turn
Re: 833 od or non? [Re: greendart408] #2985486
11/15/21 04:41 PM
11/15/21 04:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the non-OD both levers are up, on the OD the front lever is down...this is because OD is located where 3rd is on the non-OD. OD is .73-1.
If you want the 3.09 gears in a non-OD, you can also find them in the '64-'65 /6 and 273 trans.
Re: 833 od or non? [Re: greendart408] #2985501
11/15/21 05:11 PM
11/15/21 05:11 PM
A727Tflite Offline
A727Tflite  Offline
Any time you get the output to turn faster than the input you have an overdrive condition.
So yes, you have an OD unit.
Re: 833 od or non? [Re: John_Kunkel] #2985505
11/15/21 05:28 PM
11/15/21 05:28 PM
oregon
oregon
Yes sir, I am aware of those also and am looking, thanks
Re: 833 od or non? [Re: A727Tflite] #2985506
11/15/21 05:30 PM
11/15/21 05:30 PM
oregon
oregon
Thanks, I was trying to make it what I wanted and pretty much knew the result, just needed clarification.
Re: 833 od or non? [Re: greendart408] #2985738
11/16/21 12:22 PM
11/16/21 12:22 PM
moparx Offline
moparx  Offline
my brother had a 76 dart that had a /6 and what we called the : "three speed 4 speed", aka the overdrive transmission.
so yes, the /6 did indeed get the od transmission. at least in model year 76.
beer
Re: 833 od or non? [Re: moparx] #2985769
11/16/21 02:14 PM
11/16/21 02:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
OD was available with a Slant.
