833 od or non?
#2985379
11/15/21 12:17 PM
11/15/21 12:17 PM
Posts: 1,073 oregon
greendart408
oregon
I have a 75 I think all iron case 833 here, a body tail housing. Can somebody tell me by the vin what it was? I’m looking for a 74-5 318, non OD 833 so I can put the low gear guts in my street strip ride for et gain. Thanks in advance
Re: 833 od or non?
[Re: greendart408]
#2985426
11/15/21 02:19 PM
11/15/21 02:19 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
"G" is the plant code for St. Louis which built Dodge Dart/Plymouth Valiant cars from '73-'76. I believe 6-cylinder cars got the non-OD trans and V-8's got the OD.
I agree, why not just shift into 1st gear and count the turns?
Re: 833 od or non?
[Re: greendart408]
#2985486
11/15/21 04:41 PM
11/15/21 04:41 PM
John_Kunkel
Rio Linda, CA
On the non-OD both levers are up, on the OD the front lever is down...this is because OD is located where 3rd is on the non-OD. OD is .73-1.
If you want the 3.09 gears in a non-OD, you can also find them in the '64-'65 /6 and 273 trans.
Re: 833 od or non?
[Re: greendart408]
#2985501
11/15/21 05:11 PM
11/15/21 05:11 PM
Posts: 3,082 Michigan
A727Tflite
I did that and it's 3.09 1st. My confusion is in 3,4th and with the lever needing to be up or down with a od and non. One gear is 1:1 and the other turns the output around 1.35 ish. So I must be a OD unit? Disregarding the lever orientation that's what I get when turning the input 1 turn Any time you get the output to turn faster than the input you have an overdrive condition. So yes, you have an OD unit.
Re: 833 od or non?
[Re: John_Kunkel]
#2985505
11/15/21 05:28 PM
11/15/21 05:28 PM
Posts: 1,073 oregon
greendart408
oregon
If you want the 3.09 gears in a non-OD, you can also find them in the '64-'65 /6 and 273 trans. Yes sir, I am aware of those also and am looking, thanks
Re: 833 od or non?
[Re: A727Tflite]
#2985506
11/15/21 05:30 PM
11/15/21 05:30 PM
Posts: 1,073 oregon
greendart408
oregon
I did that and it's 3.09 1st. My confusion is in 3,4th and with the lever needing to be up or down with a od and non. One gear is 1:1 and the other turns the output around 1.35 ish. So I must be a OD unit? Disregarding the lever orientation that's what I get when turning the input 1 turn Any time you get the output to turn faster than the input you have an overdrive condition. So yes, you have an OD unit. Thanks, I was trying to make it what I wanted and pretty much knew the result, just needed clarification.
