Recommendation wanted to remove paint from a metal bench #2985284
11/14/21 10:31 PM
11/14/21 10:31 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
I have metal industrial work bench top face plate that needs to be repainted (gray). Any inexpensive recommendations to remove old paint/surface rust? Any liquid product or tool better than the other? Sandpaper, polycarbide abrasive, or wire wheel?
The item will not fit in a media blast cabinet. The metal face plate is roughly 6' x 1.5".
Re: Recommendation wanted to remove paint from a metal bench [Re: vinnyd76] #2985294
11/14/21 10:43 PM
11/14/21 10:43 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Oven cleaner.
Re: Recommendation wanted to remove paint from a metal bench [Re: John Brown] #2985301
11/14/21 11:10 PM
11/14/21 11:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
3M paint removal disc from the hardware store, and you can use them on other stuff too.
Re: Recommendation wanted to remove paint from a metal bench [Re: vinnyd76] #2985314
11/15/21 12:09 AM
11/15/21 12:09 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
First off what metal is it? Brass, aluminum, steel, stainless steel, etc. etc. Secondly, are the dimensions accurate? Is it only 1 1/2 inches wide?
Re: Recommendation wanted to remove paint from a metal bench [Re: 6PakBee] #2985377
11/15/21 12:15 PM
11/15/21 12:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd be inclined to use a D-A and some 80-grit after degreasing the top.
Depending on the intended use, maybe no new paint, progressively finer grits until you get as smooth a surface as you want.
Or cover it with a metal sheet, wood, whatever - again depending on intended use.
For repainting I'm thinking some kind of 2-part epoxy for fuel/solvent resistance.
Re: Recommendation wanted to remove paint from a metal bench [Re: 6PakBee] #2985516
11/15/21 06:27 PM
11/15/21 06:27 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Here is a photo of the face plate on the steel work bench. The bench has three shields (LH, RH, and rear) to prevent items from rolling of as well as this face plate to attach to the front edge of the bench top to finish it off and hold down a thin piece of wood/plastic, if the person decides not work on the steel surface top.
Re: Recommendation wanted to remove paint from a metal bench [Re: vinnyd76] #2985526
11/15/21 07:05 PM
11/15/21 07:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Recommendation wanted to remove paint from a metal bench [Re: topside] #2985600
11/15/21 10:03 PM
11/15/21 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll bet that paint is pretty thin so 80 may be a bit aggressive IMO. Id start with something like maybe 320 and go down if needed or try the oven cleaner. Acetone with a SS kitchen scrub might work in a well ventilated area
shruggy twocents beer
Re: Recommendation wanted to remove paint from a metal bench [Re: TJP] #2985663
11/16/21 01:55 AM
11/16/21 01:55 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Recommendation wanted to remove paint from a metal bench [Re: vinnyd76] #2985699
11/16/21 09:27 AM
11/16/21 09:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Recommendation wanted to remove paint from a metal bench [Re: ZIPPY] #3064826
08/03/22 08:28 AM
08/03/22 08:28 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Update: I finally got around to removing the paint from a few metal workbench pieces with oven cleaner. Overall, I thought the oven cleaner loosened/removed a majority of the paint from the metal. I simply sprayed the product on the metal surfaces and allowed it to work for roughly an hour before attempting to remove paint. A majority of the paint was cleared from the metal using plastic putty knife.
I wore a mask, safety glasses and gloves. The job was completed outside in the yard.
Thank you for the input!
