Re: Recommendation wanted to remove paint from a metal bench
[Re: vinnyd76]
#2985314
11/15/21 12:09 AM
11/15/21 12:09 AM
Posts: 10,721 North Dakota
6PakBee
North Dakota
I have metal industrial work bench top face plate that needs to be repainted (gray). Any inexpensive recommendations to remove old paint/surface rust? Any liquid product or tool better than the other? Sandpaper, polycarbide abrasive, or wire wheel?
The item will not fit in a media blast cabinet. The metal face plate is roughly 6' x 1.5". First off what metal is it? Brass, aluminum, steel, stainless steel, etc. etc. Secondly, are the dimensions accurate? Is it only 1 1/2 inches wide?
[Re: 6PakBee]
#2985516
11/15/21 06:27 PM
11/15/21 06:27 PM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
The item will not fit in a media blast cabinet. The metal face plate is roughly 6' x 1.5". First off what metal is it? Brass, aluminum, steel, stainless steel, etc. etc. Secondly, are the dimensions accurate? Is it only 1 1/2 inches wide? Here is a photo of the face plate on the steel work bench. The bench has three shields (LH, RH, and rear) to prevent items from rolling of as well as this face plate to attach to the front edge of the bench top to finish it off and hold down a thin piece of wood/plastic, if the person decides not work on the steel surface top.
[Re: vinnyd76]
#2985526
11/15/21 07:05 PM
11/15/21 07:05 PM
Posts: 20,593 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
