Re: 6 point roll bar cost
[Re: gregcharger72]
#2983748
11/10/21 10:17 AM
11/10/21 10:17 AM
Posts: 4,683 Wichita
GY3
Wichita
Wow, that's kinda crazy.
Mine was $600 about 4 years ago and at that time they said the price was going up right after. I think the one in my neighbors Chevelle ended up being ~$1,000 last year. Both mild steel, 6 point, unpainted. His had swingouts on both doors.
[Re: GY3]
#2983753
11/10/21 10:25 AM
11/10/21 10:25 AM
Posts: 10,032 MN
JERICOGTX
MN
IMO a Moly bar, as you described today should be around $2500-3000. There is a lot more work involved in building a bar/cage, than most people know.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2983754
11/10/21 10:28 AM
11/10/21 10:28 AM
GY3
Wichita
I will say painting one is a giant PITA!
[Re: GY3]
#2983756
11/10/21 10:31 AM
11/10/21 10:31 AM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
i just bought a 8 pt kit from S&W in PA. $299 M/S i have a tig welder on call, C/M will be twice as much gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#2983768
11/10/21 10:58 AM
11/10/21 10:58 AM
Posts: 10,032 MN
JERICOGTX
MN
I'm sure I'll piss some people off, but "kits" fit like garbage. There is a big difference between a custom bent cage for YOUR car, vs. a kit that anyone can install.
69 GTX
68 Road Runner
[Re: 440lebaron]
#2983802
11/10/21 12:26 PM
11/10/21 12:26 PM
Posts: 11,716 Portage,michigan
B3422W5
Portage,michigan
That is what i have. Highly, highly, highly recommend the 8 point over the 6 point. The two extra bars angle down from the main hoop to the rear seat footwells and tie into the frame connectors. Makes for a much more rigid chassis
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2983803
11/10/21 12:41 PM
11/10/21 12:41 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
That is what i have. Highly, highly, highly recommend the 8 point over the 6 point. The two extra bars angle down from the main hoop to the rear seat footwells and tie into the frame connectors. Makes for a much more rigid chassis Could you post pics? thanks.
[Re: B3422W5]
#2983814
11/10/21 01:33 PM
11/10/21 01:33 PM
Posts: 47 S.E. Michigan
TruPerformance
S.E. Michigan
I paid $2500 for a custom fit chrome moly 8-point installed in my wife's car (un-painted). She wanted swing-out bars and my buddy talked her out of it, and after he explained why it made perfect sense to us... He said that the swing out bars will rattle and annoy the sh#t out of you no matter how good the fit over time. So, he put a nice bend to make it easy to get in and out of the car, and we're very happy (kept the factory arm rests). The painting is a pain in the a$$. So, the extra money they are charging is probably pure labor for the amount of time it is going to take to paint! It takes a Looong time. I still haven't finished getting the trunk bars painted. Lots of masking and taping. Many hours. So, if you aren't willing to do the painting yourself, i can see it costing a lot of money!
1963 Belvedere (mine) 1969 Roadrunner (wife's)
[Re: TruPerformance]
#2983836
11/10/21 02:43 PM
11/10/21 02:43 PM
GY3
Wichita
I still haven't finished getting the trunk bars painted. Ha! Me either.
[Re: GY3]
#2983843
11/10/21 03:10 PM
11/10/21 03:10 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
I do not have a ton of race car experience like some of the other guys here. That said, if you are only doing a 6 point, why bother with the Chromoly? The delta in material cost between mild steel and Chromoly is quite a bit. I'm just assuming that if a 6 point is sufficient for the plans you have for your car, then Chromoly is not a requirement.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: DrCharles]
#2983961
11/10/21 09:27 PM
11/10/21 09:27 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sounds about right. What does that include besides paint?
Materials and consumables have gone up along with everything else. Paint a bar/cage with the right paint and do it right? That's a job itself.
1320 isn't a couple of guys installing kits on the side. Glen Burnie isn't out on the side of a mountain somewhere. That's the high rent district. So, yeah. Sounds about right.
[Re: gregcharger72]
#2983982
11/10/21 10:44 PM
11/10/21 10:44 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
so I've decided to put a 6 point roll bar in my car but i want to keep the interior intact , i got an estimate from a fabrication shop on a chrome moly , tig welded , drivers side swing out bar and fully painted with an epoxy paint for 4500$ . man that seems really expensive! But I've never had one done and my buddy's had theirs done 10 15 years ago so their cost really doesn't compare now... is this price now reasonable? it's a shop with a good reputation, 1320 fabrication in Glen Burnie MD. what are your thoughts.' Getting one custom installed/fit to your car is the best way. However, I have seen some kits that fit pretty damn good in some Mopars and other brand cars IF patience, time and pride is taken into consideration on the install. $4500 is way over-priced for a 6-point. Look elsewhere for a quality shop.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: justinp61]
#2984054
11/11/21 10:07 AM
11/11/21 10:07 AM
440lebaron
westerly, ri. usa
DOING side bars and bars from cross bar to floor next week end, M/S tig S&W kit fit perfect
gary yes its a cordoba
[Re: DrCharles]
#2984168
11/11/21 03:53 PM
11/11/21 03:53 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Pictures of my roll bars ... yes, needs a repainting. Also included two pictures of through-the-floor the subframe connectors. The unibody was very flexible before installation. It's very rigid now.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#2984279
11/11/21 09:12 PM
11/11/21 09:12 PM
Posts: 169 Sticky South
Rodenteliminator
Sticky South
I bought my 12 point thru Applied Racing Technology in Clearwater Fl. a couple of years back and it fit very well up and tight (67 BBody) with plenty of extra pipe, good guys to work with and they have a good bunch of programs for about any vehicle.
Sorry honey I spent the rent
#2985003
11/14/21 12:54 AM
11/14/21 12:54 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Aluminum foil is your friend when painting a cage. Much better than masking paper and tape
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: JERICOGTX]
#2985278
11/14/21 10:26 PM
11/14/21 10:26 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
[/quote] I'm sure I'll piss some people off, but "kits" fit like garbage. There is a big difference between a custom bent cage for YOUR car, vs. a kit that anyone can install. [/quote] I have had occasions in life where the truth pissed me off. This isn't one of them. I have installed S&W , Art Morrison and Alston kits in cars................the fit was what I made it , and trying to put one of them in " as is " just ain't happening.
[Re: justinp61]
#2985291
11/14/21 10:41 PM
11/14/21 10:41 PM
Posts: 3,196 Md.
carnut68
Md.
The bar in my Dart came from S&W, everything was long so it could be fit up nice and tight. The main hoop is within 1/2" of the inner panel on each side. It's better than I expected and wouldn't hesitate to use them again. The painting is a pain but I brushed o a hammered finish paint and it came out well. Same here. I measured made sure car was level then cut and tacked it together and a friend who could weld finished it up. The car really stiffened up after adding the frame connectors and bar.
America First!
