6 point roll bar cost #2983746
11/10/21 10:09 AM
11/10/21 10:09 AM
pa
gregcharger72 Offline OP
pa
so I've decided to put a 6 point roll bar in my car but i want to keep the interior intact , i got an estimate from a fabrication shop on a chrome moly , tig welded , drivers side swing out bar and fully painted with an epoxy paint for 4500$ . man that seems really expensive! But I've never had one done and my buddy's had theirs done 10 15 years ago so their cost really doesn't compare now... is this price now reasonable? it's a shop with a good reputation, 1320 fabrication in Glen Burnie MD. what are your thoughts.'
Re: 6 point roll bar cost [Re: gregcharger72] #2983748
11/10/21 10:17 AM
11/10/21 10:17 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Wow, that's kinda crazy.
Mine was $600 about 4 years ago and at that time they said the price was going up right after. I think the one in my neighbors Chevelle ended up being ~$1,000 last year. Both mild steel, 6 point, unpainted. His had swingouts on both doors.
'63 Dodge 330
11.19 @ 121 mph
Re: 6 point roll bar cost [Re: GY3] #2983753
11/10/21 10:25 AM
11/10/21 10:25 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
IMO a Moly bar, as you described today should be around $2500-3000. There is a lot more work involved in building a bar/cage, than most people know.
69 GTX 68 Road Runner
Re: 6 point roll bar cost [Re: JERICOGTX] #2983754
11/10/21 10:28 AM
11/10/21 10:28 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I will say painting one is a giant PITA!
'63 Dodge 330
11.19 @ 121 mph
Re: 6 point roll bar cost [Re: GY3] #2983756
11/10/21 10:31 AM
11/10/21 10:31 AM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i just bought a 8 pt kit from S&W in PA. $299 M/S i have a tig welder on call, C/M will be twice as much
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 6 point roll bar cost [Re: 440lebaron] #2983768
11/10/21 10:58 AM
11/10/21 10:58 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
gary
I'm sure I'll piss some people off, but "kits" fit like garbage. There is a big difference between a custom bent cage for YOUR car, vs. a kit that anyone can install.
Re: 6 point roll bar cost [Re: JERICOGTX] #2983797
11/10/21 11:54 AM
11/10/21 11:54 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
and labor, bending, cutting and fitting mitres. also tig welding goes a bit slower than mig...
Re: 6 point roll bar cost [Re: 440lebaron] #2983802
11/10/21 12:26 PM
11/10/21 12:26 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
gary
That is what i have.
Highly, highly, highly recommend the 8 point over the 6 point. The two extra bars angle down from the main hoop to the rear seat footwells and tie into the frame connectors.
Makes for a much more rigid chassis
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 6 point roll bar cost [Re: B3422W5] #2983803
11/10/21 12:41 PM
11/10/21 12:41 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
gary
Could you post pics? thanks.
Re: 6 point roll bar cost [Re: DrCharles] #2983804
11/10/21 12:49 PM
11/10/21 12:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
https://swracecars.com/product/dart-dodgeswinger-plymouth-scamp-valiant-1967-1976-8-point-roll-bar/
The two bars labeled “ lateral support bars” are the two i am refering to.
We hole saw and pass those two bars through the floor boards in the rear footwells and weld them to the frame connectors.
1.41 best 60 foot
6.56 at 104.17
Re: 6 point roll bar cost [Re: B3422W5] #2983814
11/10/21 01:33 PM
11/10/21 01:33 PM
S.E. Michigan
TruPerformance Offline
S.E. Michigan
I paid $2500 for a custom fit chrome moly 8-point installed in my wife's car (un-painted). She wanted swing-out bars and my buddy talked her out of it, and after he explained why it made perfect sense to us... He said that the swing out bars will rattle and annoy the sh#t out of you no matter how good the fit over time. So, he put a nice bend to make it easy to get in and out of the car, and we're very happy (kept the factory arm rests). The painting is a pain in the a$$. So, the extra money they are charging is probably pure labor for the amount of time it is going to take to paint! It takes a Looong time. I still haven't finished getting the trunk bars painted. Lots of masking and taping. Many hours. So, if you aren't willing to do the painting yourself, i can see it costing a lot of money!
1963 Belvedere (mine)
1969 Roadrunner (wife's)
Re: 6 point roll bar cost [Re: TruPerformance] #2983836
11/10/21 02:43 PM
11/10/21 02:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Ha! Me either. primer
'63 Dodge 330
11.19 @ 121 mph
Re: 6 point roll bar cost [Re: GY3] #2983843
11/10/21 03:10 PM
11/10/21 03:10 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I do not have a ton of race car experience like some of the other guys here. That said, if you are only doing a 6 point, why bother with the Chromoly? The delta in material cost between mild steel and Chromoly is quite a bit. I'm just assuming that if a 6 point is sufficient for the plans you have for your car, then Chromoly is not a requirement.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: 6 point roll bar cost [Re: gregcharger72] #2983846
11/10/21 03:22 PM
11/10/21 03:22 PM
Call Bob George racing (724-941-4251)and ask them about doing your car, they are Mopar racers and have a excellent reputation. scope twocents
Re: 6 point roll bar cost [Re: B3422W5] #2983910
11/10/21 07:14 PM
11/10/21 07:14 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Thanks, I have already been on the S&W website before posting. What I wanted to see was pictures of your actual installation from a few different angles smile
Re: 6 point roll bar cost [Re: DrCharles] #2983961
11/10/21 09:27 PM
11/10/21 09:27 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sounds about right. What does that include besides paint?
Materials and consumables have gone up along with everything else. Paint a bar/cage with the right paint and do it right? That's a job itself.
1320 isn't a couple of guys installing kits on the side. Glen Burnie isn't out on the side of a mountain somewhere. That's the high rent district.
So, yeah. Sounds about right.
Re: 6 point roll bar cost [Re: gregcharger72] #2983966
11/10/21 09:35 PM
11/10/21 09:35 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I think it is a bit high for a 6 point roll bar. I know most shops are busy now and even heard some are charging $300 just to put you on a list.
One nice advantage you have is there are a lot chassis shops in MD and PA. I'd get another quote.
Re: 6 point roll bar cost [Re: gregcharger72] #2983982
11/10/21 10:44 PM
11/10/21 10:44 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Getting one custom installed/fit to your car is the best way. However, I have seen some kits that fit pretty damn good in some Mopars and other brand cars IF patience, time and pride is taken into consideration on the install. $4500 is way over-priced for a 6-point. Look elsewhere for a quality shop.
"Any fool can know. The point is to understand"
- A. Einstein
Re: 6 point roll bar cost [Re: EvilB1Dart] #2983994
11/10/21 11:46 PM
11/10/21 11:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The bar in my Dart came from S&W, everything was long so it could be fit up nice and tight. The main hoop is within 1/2" of the inner panel on each side. It's better than I expected and wouldn't hesitate to use them again. The painting is a pain but I brushed o a hammered finish paint and it came out well.
Re: 6 point roll bar cost [Re: gregcharger72] #2984053
11/11/21 10:06 AM
11/11/21 10:06 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
$100 a weld + material will get you close molly needs to be tig welded
