hellcat swap, oil relocation - pressure sensors #2981556
11/04/21 05:41 AM
11/04/21 05:41 AM
Netherlands
72Challenger Offline OP
Netherlands
Hi to all here,
Doing a Hellcat swap at the moment redoing eveyrting on my 72 Challenger so got out the older engine and installing a Hellcat. Using TTI headers and their mounts which needs (my guess) me to use a oil flilter block off plate and go to a remote setuop using the plugs above the filter to install the lines to the remote filter. But where could I put the engines oil sensor for the ecu and what about the 'old style' sensors for the dash gauge? cant seem to find it online somehow so thought to ask here.
Thanks for any help!
Re: hellcat swap, oil relocation - pressure sensors [Re: 72Challenger] #2981781
11/04/21 07:19 PM
11/04/21 07:19 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I’m wondering if the new harness from Mopar Performance has remedied that problem? It might be worth looking into since they seem to have done some of the research into older vehicle conversions.
Re: hellcat swap, oil relocation - pressure sensors [Re: migsBIG] #2981854
11/04/21 10:19 PM
11/04/21 10:19 PM
IL
furious70 Offline
furious70  Offline
IL
if running a remote filter you would have plenty of opportunity to plumb in both sensors, right? Not sure if I'm missing something.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: hellcat swap, oil relocation - pressure sensors [Re: 72Challenger] #2981881
11/05/21 12:02 AM
11/05/21 12:02 AM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
I completed my hellcat swap in my 1970 GTX this past spring and couldnt be happier with the car. For mine, I used TTI headers and their mounts with the stock K member. I used the 45 degree adapter for the oil filter. I had to use it or go remote for fitment. If your using the stock gauges, you can adapt the factory sensors with fittings to the block. The engine itself has a separate oil pressure sensor for the ecu that it reads. In my case I have a Dakota Digital Dash, and they have a module that uses the factory readings off the ECU to power the gauges. If you havent already, PLEASE , remove your K member , make a dolly for it, and assemble everything for fitment on it before you install the engine, and install everything from the bottom. You will be sorry if you dont fit everything first. Hope this helps.
Re: hellcat swap, oil relocation - pressure sensors [Re: 72Challenger] #2981916
11/05/21 05:51 AM
11/05/21 05:51 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
There should be an oil pressure port immediately above the filter housing on the front face of the block.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: hellcat swap, oil relocation - pressure sensors [Re: A39Coronet] #2981920
11/05/21 07:14 AM
11/05/21 07:14 AM
Netherlands
Netherlands
Thanks for the input guys! Will take care of it.
Thought a 45 degree adapter didnt fit with TTI mounts as there is not much space between it but looks like there is enough so will try that, then I can use the plugs above on the side / front for the sensors.
Have installed the engine from above, peace of cake I have to say, just dropped it on the kmember and added the T56 later on. Wiring is mostly done but takes lot of time in total as I'm doing the whole car, from paint to brakes to interior.
Thanks again,
Hans
Re: hellcat swap, oil relocation - pressure sensors [Re: 72Challenger] #2981966
11/05/21 10:13 AM
11/05/21 10:13 AM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
On my 45 degree adapter, I did have to trim the drip rail about an inch or so, not sure how an e body would be. I had a lot of little fitment issues with my headers, power steering ( borgeson) and starter, that would of been a nightmare if i had the engine in first. BTW, if you are using the MP hellcrate controller kit, make sure all your sensors are from a 2015-2017 engine. Ive seen a few people use a 2018 engine and up, and not change out the sensors and have issues, mainly the MAP sensors, they are different, Good luck.
Re: hellcat swap, oil relocation - pressure sensors [Re: 70gtx1] #2982616
11/07/21 07:51 AM
11/07/21 07:51 AM
BDW Offline
BDW  Offline
I was just at Garlits car show this weekend and had long conversation with a guy who had his 72 Challenger with Hellcat motor there.
He used the Bouchillion 90 deg adapter with TTI mounts and headers, stock K-frame and power steering pumo .
It all fit with no issues.
Makes me wish I hadn't just dropped $900 for the Borgeson gear.
https://www.bouchillonperformance.com/inc/sdetail/10629/20785
Re: hellcat swap, oil relocation - pressure sensors [Re: BDW] #2982681
11/07/21 11:09 AM
11/07/21 11:09 AM
K
Kiddart Offline
Kiddart  Offline
K
I have to go look at my car, but i dont think this 90 degree will work with spool mounts, just tossing this out there.
Thank you
Kiddart
Re: hellcat swap, oil relocation - pressure sensors [Re: Kiddart] #2982862
11/07/21 06:43 PM
11/07/21 06:43 PM
BDW Offline
BDW  Offline
Please post a pic of what you have.
I have both the Schumacher mounts (bought awhile back) and the Holley mounts.
Would really like to use the Schumacher parts, very good looking pieces, really would like to not have to use the crappy rubber biscuits.
Re: hellcat swap, oil relocation - pressure sensors [Re: BDW] #2983375
11/09/21 11:31 AM
11/09/21 11:31 AM
IL
furious70 Offline
furious70  Offline
IL
The Borg gear has it's own merits as a steering upgrade though, so not all it lost.
70 Sport Fury
68 Charger
69 Coronet
72 RR
