Broken throttle cable #2973752
10/12/21 11:22 PM
10/12/21 11:22 PM
Dearborn Hts, MI
Sledge_57 Offline OP
Dearborn Hts, MI
My cable broke today (ball at pedal) and has always seemed a bit short.
With a M1 intake and Andy F's bracket I was just able to get it to reach with a bit of slack at the carb but between the bracket and firewall it's pulled as tight as it'll go.
So my question is what cable to replace it with? Is there a Mopar, longer than stock cable that'll work on a 67 B body, or should I just use aftermarket?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Broken throttle cable [Re: Sledge_57] #2973759
10/13/21 12:07 AM
10/13/21 12:07 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I’m thinking Lokar makes one that will fit properly.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Broken throttle cable [Re: Sledge_57] #2973760
10/13/21 12:20 AM
10/13/21 12:20 AM
AndyF Offline
AndyF  Offline
The /6 cables were the longest so you can try one of those. First step is to measure your old cable and then take a look at what is available for reproduction cables. Mancini Racing has a bunch of throttle cables for sale.
Re: Broken throttle cable [Re: AndyF] #2973761
10/13/21 12:26 AM
10/13/21 12:26 AM
Dearborn Hts, MI
Dearborn Hts, MI
Thanks!
Doug
Re: Broken throttle cable [Re: AndyF] #2973774
10/13/21 02:36 AM
10/13/21 02:36 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Link.
https://www.manciniracing.com/hemthrotcab.html
Re: Broken throttle cable [Re: SNK-EYZ] #2973970
10/13/21 02:39 PM
10/13/21 02:39 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Just because it happened to me and it could have been bad. I just replaced mine with the small block repo cable. The issue I had was the bell on the carb end when at full throttle slides over the necked down area where the cable exits the sheathing. The bracket was holding the cable very slightly off plane. So that when it went to full throttle the sideways pressure on the bell held it there. Even with two return springs. I cut off the bell mouth. Just double check that it won’t bind!
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Broken throttle cable [Re: FurryStump] #2975579
10/18/21 10:18 AM
10/18/21 10:18 AM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
I replaced mine on my Duster with a Mancini Racing cable. twocents
Plymouth Makes It!
Re: Broken throttle cable [Re: Sledge_57] #2975687
10/18/21 02:35 PM
10/18/21 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Broken throttle cable [Re: ZIPPY] #2978044
10/24/21 10:50 PM
10/24/21 10:50 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Originally Posted by ZIPPY
That is my "go-to" along with the AR Engineering bracketry for correct alignment.
Re: Broken throttle cable [Re: Jeremiah] #2979627
10/29/21 02:54 PM
10/29/21 02:54 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Broken cables are usually from the carburetor getting to full throttle before the pedal reaches the floor.
Re: Broken throttle cable [Re: Sledge_57] #2979695
10/29/21 07:04 PM
10/29/21 07:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
What motor came in the car originally?
I've had throttle pedal issues in the past when swapping motors from a SB 2 barrel motor or even a B motor two barrel motor to a four barrel carb and intake.
The six cylinder cars are a snap to reuse their throttle cables on almost any V8 without a six pack intake on them up
The six pack cables need to be a lot shorter than the stock six cylinder throttle cables shruggy
their are two different types pf stock throttle cables, probably early and later confused
Re: Broken throttle cable [Re: Cab_Burge] #2979715
10/29/21 08:47 PM
10/29/21 08:47 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I still have my original slant cable and it works perfect beer
Gus beer
64 Plymouth Savoy
Dana 60
