8 3/4 rear #2979629
10/29/21 02:54 PM
10/29/21 02:54 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
im having a c body rear end narrowed to fit my 73 dart to replace the 7 1/4 . the c body rear has no brakes or backing plates . i was told that the large bolt pattern 7 1/4 brakes wont fit the 8 3/4 . what do i need?
ted
5549 post on old board
Re: 8 3/4 rear [Re: 05dakota] #2979639
10/29/21 03:32 PM
10/29/21 03:32 PM
AndyF Offline
AndyF  Offline
Doctor Diff has rear drum assemblies including the backing plate. Either that or find something in a wrecking yard or switch to a disc brake.
Re: 8 3/4 rear [Re: AndyF] #2979643
10/29/21 03:43 PM
10/29/21 03:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mopar Madness has complete loaded rear drums for $490 on E-bay.
Dr. Diff is a bit cheaper.
https://www.doctordiff.com/mopar-drum-brake-assembly.html
Re: 8 3/4 rear [Re: 05dakota] #2979655
10/29/21 04:29 PM
10/29/21 04:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The 8 3/4 should have 3" axle tubes. Either 8 1/4 or 8 3/4 should work. Should be some of that stuff around for less than $500. You might hit the B, E, and full size for sale section.
Master, again and still
Re: 8 3/4 rear [Re: 05dakota] #2979660
10/29/21 04:49 PM
10/29/21 04:49 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
If you buy a brake "kit" be sure it comes with everything you need for the parking brake. I bought one built similar, cut down C-body in an A-body, and brakes were included but didn't include the parking brake arm so I had to take them mostly apart to stick those in.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: 8 3/4 rear [Re: Bob Stinson] #2979667
10/29/21 05:11 PM
10/29/21 05:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Years ago I installed the backing plates/brakes/drums off of a 7-1/4(out of an 82 Cordoba) onto an 8-3/4. They bolted right up...unless my memory is becoming fuzzy.
Re: 8 3/4 rear [Re: burdar] #2979677
10/29/21 06:06 PM
10/29/21 06:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
LBP 10" brakes off a 7-1/4 will bolt right on an 8-3/4. Just make sure your axle bearings are spaced correctly for the LBP brakes. They will also fit an 8-1/4.
SBP brakes off a 7-1/4 won't bolt on to either. The wheel bearing is smaller.
Re: 8 3/4 rear [Re: slantzilla] #2979679
10/29/21 06:19 PM
10/29/21 06:19 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
I thought 7-1/4 rears have a 4-bolt backing plate while an 8-3/4 has a 5 bolt... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 8 3/4 rear [Re: Rhinodart] #2979726
10/29/21 09:12 PM
10/29/21 09:12 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Small bolt pattern do have the 4 bolt retainer. The 73 and up big bolt pattern have the 5 bolt and the bigger axle bearing.
Re: 8 3/4 rear [Re: slantzilla] #2979741
10/29/21 09:56 PM
10/29/21 09:56 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
10 x 2 1/2" backing plates will bolt to a C-body housing if you grind the top of the housing ends.
