8 3/4 rear
#2979629
10/29/21 02:54 PM
10/29/21 02:54 PM
Posts: 17,861 albany ny
05dakota
albany ny
im having a c body rear end narrowed to fit my 73 dart to replace the 7 1/4 . the c body rear has no brakes or backing plates . i was told that the large bolt pattern 7 1/4 brakes wont fit the 8 3/4 . what do i need?
ted
5549 post on old board
Re: 8 3/4 rear
[Re: 05dakota]
#2979655
10/29/21 04:29 PM
10/29/21 04:29 PM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The 8 3/4 should have 3" axle tubes. Either 8 1/4 or 8 3/4 should work. Should be some of that stuff around for less than $500. You might hit the B, E, and full size for sale section.
Master, again and still
Re: 8 3/4 rear
[Re: 05dakota]
#2979660
10/29/21 04:49 PM
10/29/21 04:49 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
If you buy a brake "kit" be sure it comes with everything you need for the parking brake. I bought one built similar, cut down C-body in an A-body, and brakes were included but didn't include the parking brake arm so I had to take them mostly apart to stick those in.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
Re: 8 3/4 rear
[Re: burdar]
#2979677
10/29/21 06:06 PM
10/29/21 06:06 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
LBP 10" brakes off a 7-1/4 will bolt right on an 8-3/4. Just make sure your axle bearings are spaced correctly for the LBP brakes. They will also fit an 8-1/4.
SBP brakes off a 7-1/4 won't bolt on to either. The wheel bearing is smaller.
Re: 8 3/4 rear
[Re: Rhinodart]
#2979726
10/29/21 09:12 PM
10/29/21 09:12 PM
slantzilla
Park Forest, IL
Small bolt pattern do have the 4 bolt retainer. The 73 and up big bolt pattern have the 5 bolt and the bigger axle bearing.
