Cheap external EFI pump? #297848
04/23/09 10:14 PM
04/23/09 10:14 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Is there some cheap aftermarket or even a "not mopar" brand of car I can get a pump for to mount outside the tank to run an EFI system on my old car? Would need around 50psi or more.
Think cheap...
Re: Cheap external EFI pump? [Re: HotRodDave] #297849
04/23/09 10:39 PM
04/23/09 10:39 PM
Andrewh Offline
Andrewh  Offline
not really. The new cars since the 90's maybe earlier are in tank fuel pumps.
The cheapest one I found was the MSD pump from summit. Right at 100 bucks.
Re: Cheap external EFI pump? [Re: HotRodDave] #297850
04/24/09 02:31 AM
04/24/09 02:31 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Walbro 392. Around $100.00.
Re: Cheap external EFI pump? [Re: goldmember] #297851
04/24/09 02:39 AM
04/24/09 02:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Walbro GSL-392. Check out this chart for the fuel flow. The 392 is the "high pressure" 255 version in the far right hand column. I've run these pumps in two different cars, tons of fuel flow and very quiet, can not hear them run over even a stock 4cyl exhaust.
http://www.autoperformanceengineering.com/html/fpspecs.html
Re: Cheap external EFI pump? [Re: HotRodDave] #297852
04/24/09 07:30 AM
04/24/09 07:30 AM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Swapped 84 Daytona Turbo drivetrain into 81 Charger. Had a 80's Volvo going to crusher sitting at the shop, fuel pump worked in the Charger.
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: Cheap external EFI pump? [Re: HotRodDave] #297853
04/24/09 12:12 PM
04/24/09 12:12 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Here's a thread I started a while back. Not many options under $100...
http://www.msefi.com/viewtopic.php?f=29&t=32737&p=201283#p201283
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Cheap external EFI pump? [Re: Fury Fan] #297854
04/24/09 01:12 PM
04/24/09 01:12 PM
Vacaville/ El Dorado Hills ,Ca
440FISH Offline
super gas
440FISH  Offline
super gas
Summit efi Pump
Only $71.95
This pump worked good for me went 11.40's in my EFI 383(454cid) a-body
For that price you can add two...
