4 speed flywheel #2978355
10/25/21 07:20 PM
10/25/21 07:20 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I have a stack of flywheels. How can i tell which is right for a 383 4 speed. Do i just pick the ones tgat match crank spacing?
68 Satellite Wagon and a few other ones
Re: 4 speed flywheel [Re: mro] #2978359
10/25/21 07:38 PM
10/25/21 07:38 PM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on which year 383 your wanting the flywheel to fit on properly with the bell housing, pre 1967 I think they only offered 10.5 clutches in passenger cars, beginning in 1968 I think they started offering the H.,D. 11 inch clutches on the 143 tooth flywheels and matching bell housings scope
Mopar change all the V8 cranks in 1962 and up to 6 bolts flanges(except the 426 hemi 8 bolt motors) and moved the flywheel closer to the back of the blocks and switch the gear drive starters at the same time.
IHTHs
Re: 4 speed flywheel [Re: Cab_Burge] #2978360
10/25/21 07:40 PM
10/25/21 07:40 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Oh boy
Re: 4 speed flywheel [Re: mro] #2978361
10/25/21 08:03 PM
10/25/21 08:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
383 4-speed will be a 130 tooth 10-1/2", pretty simple if you tell us what car and year...
JB Rhinehart, Realist
A-Body's RULE!
Re: 4 speed flywheel [Re: Rhinodart] #2978362
10/25/21 08:16 PM
10/25/21 08:16 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Its for a stock 69 RR
Re: 4 speed flywheel [Re: mro] #2978403
10/25/21 09:54 PM
10/25/21 09:54 PM
VA
dragon slayer Offline
VA
It is year based not motor except for hemi. Has to match the bell housing. The 69 would be a 143 tooth. 70 is when they moved to the 130 tooth FW for Big Blocks and Hemi. Then you need to match it to the crank. Internal versus External balance, and there where cast crank FW too.
Re: 4 speed flywheel [Re: mro] #2978419
10/25/21 10:34 PM
10/25/21 10:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you have the bell housing and the transmission yet ? Just measure and count the teeth and make sure you have the correct bell for your flywheel and input retainer pilot.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4 speed flywheel [Re: mro] #2978496
10/26/21 09:20 AM
10/26/21 09:20 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
11” 143 tooth and matching bell for 69 383. But any 318-340-383 10.5 flywheel will fit to with the right bell. Do you have all the bellhousings?
Re: 4 speed flywheel [Re: cudaman1969] #2978505
10/26/21 09:42 AM
10/26/21 09:42 AM
VA
VA
The reason you start with bell housing is starter engagement to the flywheel diameter. A stock 69 RR with 383 would have had the 69 bellhousing and the 143 tooth flywheel. If that bellhousing is correct for 69 or even 68, then you get the 143 tooth, turn them over and post a picture of back side. Internally balance 69 383 motor would have a fw without extra large holes partially drilled to compensate for an externally balanced motor.
