4 speed flywheel
#2978355
10/25/21 07:20 PM
10/25/21 07:20 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
I have a stack of flywheels. How can i tell which is right for a 383 4 speed. Do i just pick the ones tgat match crank spacing?
68 Satellite Wagon and a few other ones
Re: 4 speed flywheel
[Re: mro]
#2978359
10/25/21 07:38 PM
10/25/21 07:38 PM
Posts: 43,247 Bend,OR USA
Cab_Burge
It depends on which year 383 your wanting the flywheel to fit on properly with the bell housing, pre 1967 I think they only offered 10.5 clutches in passenger cars, beginning in 1968 I think they started offering the H.,D. 11 inch clutches on the 143 tooth flywheels and matching bell housings Mopar change all the V8 cranks in 1962 and up to 6 bolts flanges(except the 426 hemi 8 bolt motors) and moved the flywheel closer to the back of the blocks and switch the gear drive starters at the same time. IHTHs
[Re: mro]
#2978361
10/25/21 08:03 PM
10/25/21 08:03 PM
Posts: 43,601 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
383 4-speed will be a 130 tooth 10-1/2", pretty simple if you tell us what car and year...
JB Rhinehart, Realist
A-Body's RULE!
[Re: mro]
#2978419
10/25/21 10:34 PM
10/25/21 10:34 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Do you have the bell housing and the transmission yet ? Just measure and count the teeth and make sure you have the correct bell for your flywheel and input retainer pilot. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
