Hemi rocker stand interchangeability #2975434
10/17/21 08:26 PM
10/17/21 08:26 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I know there was just a good thread on here about rocker stands.
I'm interested to find out whether ANY stand will bolt to ANY head, regardless of actual rockershaft positioning.
If I find a "deal" on a pair of heads, are there any heads that require unique and unobtainable stands ?
I'm just not hip on the stand interchangeability.
So then, Part II:
If you get a set of rare and wonderful stands that re-position the shafts, for whatever reason :
Is it commonplace to need compatible rocker arms that are longer, or shorter, or unobtainable, or..........??
Are 95% of Hemis all interchangeable and only 5% rare/weird ?
I don't mean any billet / nitro / race stuff.
Re: Hemi rocker stand interchangeability [Re: hemienvy] #2975441
10/17/21 09:05 PM
10/17/21 09:05 PM
A727Tflite Online content
A727Tflite  Online Content
1964 - 1971 Hemi stands all attach the same way.
There were two basic stand heights - Street Hemi and 2” Race Hemi. I believe there was another design, very rare, D Head I think.
Re: Hemi rocker stand interchangeability [Re: A727Tflite] #2975998
10/19/21 09:19 AM
10/19/21 09:19 AM
VA
dragon slayer Offline
VA
You just need to make sure they have not been modified by former racers. Milled, drilled for larger bolts etc... But as stated they were standard though the later versions had the larger pad rocker. Each set needs to be shimmed so the rocker contact to valve is correct.
Re: Hemi rocker stand interchangeability [Re: dragon slayer] #2976003
10/19/21 09:35 AM
10/19/21 09:35 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Chrysler stands yes, more or less. "Normal" 426 Hemi stands are all the same. Experimental stuff, D-5, rectangle port heads, 2" valve gear, there's always exceptions. But all the different guys that make heads/stands for Top Fuel etc, that can all be odd ball stuff.
2011 Drag Pak Challenger
Re: Hemi rocker stand interchangeability [Re: dragon slayer] #2976094
10/19/21 01:07 PM
10/19/21 01:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Correcting the rocker geometry by shimming (or machining) the stand height does not have the same effect on the intake and exhaust rockers (even though the same amount is added/removed).
To change only one side require the stand bases to be cut at an angle (different height for intakes vs. exhausts), then re-face all bolts to the new alignment. Has it been done? IDK.
The intake and exhaust rockers are different lengths, the same .060" etc. shim rotates the shorter intake rocker more degrees than the exhaust rockers. A lash cap (on either side) may help.
AFAIK, attempting to get "mid lift" (with the rockers at 50% lift when a line through the rocker pad and shaft center is 90° to the valve stem) is impossible because tip scrubbing is part of the original design (some roller rockers may allow this, Jim Miller claims they don't). Making the valve side 50% just transfers the error to the pushrod side.
Boffin Emeritus
Re: Hemi rocker stand interchangeability [Re: polyspheric] #2976458
10/20/21 12:31 PM
10/20/21 12:31 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
On HEMIs it is more important to have a centered rocker/valve tip pattern on the Intake side vs the exhaust side due to the more aggressive arc of the intake rocker (side loading of the stem). I have has success correcting rocker/valve tip aligmnet by moving the stands up or down. This requires opening the dowel locating holes so they can be moved. Typicaly I open them to .375 and use cam bushings to set and hold their position.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
