Should I Use Loctite on My Torque Converter Bolts? #297098
04/22/09 11:56 PM
04/22/09 11:56 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
Yes or no? If yes, should I use red or blue? Thanks!
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 67Satty] #297099
04/22/09 11:56 PM
04/22/09 11:56 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yes, red.
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: In_The_Pink] #297100
04/22/09 11:59 PM
04/22/09 11:59 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes, red.
x2 I've used blue since i thought i had red, but didn't. Haven't had any problems, but red is the preferred.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: GoodysGotaCuda] #297101
04/23/09 12:04 AM
04/23/09 12:04 AM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
What if I ever want to swap my converter for a different one? Will I have to break out the torch to get the bolts off with the red?
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: GoodysGotaCuda] #297102
04/23/09 12:05 AM
04/23/09 12:05 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have never used locktite on convertor bolts (or even flexplate bolts). I guess it can't hurt anything using it. I seem to have good luck with fine thread fasteners staying tight. Anything coarse thread is another story....
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: Neil] #297103
04/23/09 12:10 AM
04/23/09 12:10 AM
blue loctite
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 67Satty] #297104
04/23/09 12:12 AM
04/23/09 12:12 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've never had a problem loosening them back up actually. Red or blue. They aren't torqued to a very tight spec to begin with.
270in/lb actually, which is about 22ft/lbs. Not much.
2020 RAM 1500
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: GoodysGotaCuda] #297105
04/23/09 12:34 AM
04/23/09 12:34 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Yes, red.
I have used red and never needed a torch to get them out
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: torkrules] #297106
04/23/09 12:41 AM
04/23/09 12:41 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I use red and also have never had to torch them..
Every time I tried to not use locktite, they came loose...
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: sthemi] #297107
04/23/09 01:50 AM
04/23/09 01:50 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Blue
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 67Satty] #297108
04/23/09 02:03 AM
04/23/09 02:03 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
Blue
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: MAVERICKSHEMI] #297109
04/23/09 02:32 AM
04/23/09 02:32 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I used Red on my clutch--flywheel to crank and pressure plate to flywheel. cheap impact from autozone hit a few times, then zipped the bolts right out.
going back in, they were a bit gummy, so it couldn't hurt to chase the threads when you pull the stuff apart.
**Photobucket sucks**
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 70Cuda383] #297110
04/23/09 07:49 AM
04/23/09 07:49 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
If parts are new or have little to no wear on the
threads use blue. If the parts are used and the threads are a little loose use red.
logan426
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: RapidRobert] #297111
04/23/09 08:13 AM
04/23/09 08:13 AM
Az
Crizila Offline
Crizila  Offline
Az
blue loctite
Red is too aggressive. Sometimes you gotta use heat to get stuff appart with red. Even seen it rip up the threads. Red is for "never taking it appart again".
Fastest 300
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: Crizila] #297112
04/23/09 01:01 PM
04/23/09 01:01 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I used Red just the other day when mounting my Flex Plate to the Crank. As for the Torque Converter Bolts, most likely I will just go with the correct Torque specs and then a little extra "Armstrong" to seat it well. This is all brand new parts going into my rebuild so an ounce of prevention is worth a pound of cure....
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 67Satty] #297113
04/23/09 01:11 PM
04/23/09 01:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Unless you want them to back out.. I've used both in the past...I think I used Red on the current build.
Coming soon!!!!
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: CR8CRSHR] #297114
04/23/09 01:11 PM
04/23/09 01:11 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Personally I used loctite red on mine but I only use a small amount. I have had the t/c bolts come loose before and it made one heck of a noise.
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: mopars4ever] #297115
04/23/09 01:13 PM
04/23/09 01:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
'aint that the truth...sounds like the motor is going to go at any second!
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: Mr.Yuck] #297116
04/23/09 03:10 PM
04/23/09 03:10 PM
Bellevue WA
360ChallengerB3 Offline
Bellevue WA
I also had the bolts work loose. Avoid the mess with loctite.
Re: Should I Use Loctite on My Torque Converter Bolts? [Re: 360ChallengerB3] #297117
04/23/09 09:51 PM
04/23/09 09:51 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Yes,
One drop of red is all it takes, dont drown them or they really may not come out..
