Re: Should I Use Loctite on My Torque Converter Bolts?
[Re: In_The_Pink]
#297100
04/22/09 11:59 PM
04/22/09 11:59 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes, red.
x2 I've used blue since i thought i had red, but didn't. Haven't had any problems, but red is the preferred.
[Re: 67Satty]
#297104
04/23/09 12:12 AM
04/23/09 12:12 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What if I ever want to swap my converter for a different one? Will I have to break out the torch to get the bolts off with the red?
I've never had a problem loosening them back up actually. Red or blue. They aren't torqued to a very tight spec to begin with.
270in/lb actually, which is about 22ft/lbs. Not much.
[Re: GoodysGotaCuda]
#297105
04/23/09 12:34 AM
04/23/09 12:34 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Yes, red.
I have used red and never needed a torch to get them out
[Re: MAVERICKSHEMI]
#297109
04/23/09 02:32 AM
04/23/09 02:32 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I used Red on my clutch--flywheel to crank and pressure plate to flywheel. cheap impact from autozone hit a few times, then zipped the bolts right out.
going back in, they were a bit gummy, so it couldn't hurt to chase the threads when you pull the stuff apart.
**Photobucket sucks**
[Re: Crizila]
#297112
04/23/09 01:01 PM
04/23/09 01:01 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
[Re: mopars4ever]
#297115
04/23/09 01:13 PM
04/23/09 01:13 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Personally I used loctite red on mine but I only use a small amount. I have had the t/c bolts come loose before and it made one heck of a noise.
'aint that the truth...sounds like the motor is going to go at any second!
[Re: Mr.Yuck]
#297116
04/23/09 03:10 PM
04/23/09 03:10 PM
Posts: 170 Bellevue WA
360ChallengerB3
Bellevue WA
I also had the bolts work loose. Avoid the mess with loctite.
