removing passenger seat from a 2014 ram #2970770
10/05/21 09:18 AM
10/05/21 09:18 AM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
had a water leak from the 3rd brake light and now the carpet is wetso i want to dry it. can i remove the pass seat by itself or does the whole seat have to come out? can i unhook the wiring harness or does the battery have to be disconnected? thanks
Re: removing passenger seat from a 2014 ram [Re: ekim] #2970797
10/05/21 10:23 AM
10/05/21 10:23 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Apples and oranges, but maybe not.
The seat bottoms on my 2001 Ram are held in by 4 bolts. Look closely under your seat to see if yours are held in similarly. A couple on mine are hard to see, so look closely.
EDIT: Detroit Muscle Technologies was making replacement gaskets for those 3rd brake light. He's a sponsor here.
Re: removing passenger seat from a 2014 ram [Re: Fat_Mike] #2970800
10/05/21 10:31 AM
10/05/21 10:31 AM
Andrewh Offline
Andrewh  Offline
not sure about yours, but becareful, if it has airbags in the seats, you can do it with the car off, but do not turn the truck back on till you plug the seat back in.
it trips a airbag light you cannot clear with a regular code reader.
Re: removing passenger seat from a 2014 ram [Re: Andrewh] #2970808
10/05/21 10:46 AM
10/05/21 10:46 AM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
i was wondering if anybody made a gasket, but i went ahead and bought the new light anyway, it was $65 which was a lot cheaper than i thought it would be.
Re: removing passenger seat from a 2014 ram [Re: ekim] #2971077
10/05/21 06:08 PM
10/05/21 06:08 PM
Wichita Kansas
6PacCuda Offline
6PacCuda  Offline
Wichita Kansas
You can remove just the passenger side. It is easier to just undo the whole seat and take it out unless you don't have help.
