Re: 68 Charger Fender Tag
[Re: Wolfe440]
#2970512
10/04/21 06:24 PM
10/04/21 06:24 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
looks like they bondoed the original tag & custom engraved it
[Re: Wolfe440]
#2970535
10/04/21 07:39 PM
10/04/21 07:39 PM
Posts: 120 North Seattle, Washington. USA
U code RR
If it is Bondoed, and it does appear to be, you should be able to turn it over and still read the back. Unless of course they did a real "professional" job and Bondoed both sides,
When seconds count...
The Police are only minutes away.
Smith and Wesson are your friends.
[Re: U code RR]
#2970551
10/04/21 08:40 PM
10/04/21 08:40 PM
Posts: 217 New Port Richey, Florida
Wolfe440
If it is Bondoed, and it does appear to be, you should be able to turn it over and still read the back. Unless of course they did a real "professional" job and Bondoed both sides, I will give that a try. Thx!
[Re: 6bblgt]
#2970612
10/04/21 11:09 PM
10/04/21 11:09 PM
Wolfe440
custom made tag the top two lines codes are combined in one line to make room for the name I noticed that after looking at other examples that it must be combined, had too many digits, not sure of my decoding with letters covered. Never did a 68 tag before, its different. The underneath will hopefully reveal the original.
