68 Charger Fender Tag #2970510
10/04/21 06:20 PM
10/04/21 06:20 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I went to see a 68 Charger some older folks bought several years ago. Its a basket case, they don't know much about its past.
I looked at the fender tag and found something like a fender tag, the screws look like its been there a long time. Got someone's name on it, weird.
I'm not sure what I'm looking at.
Re: 68 Charger Fender Tag [Re: Wolfe440] #2970512
10/04/21 06:24 PM
10/04/21 06:24 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
looks like they bondoed the original tag & custom engraved it
Re: 68 Charger Fender Tag [Re: CSK] #2970517
10/04/21 06:28 PM
10/04/21 06:28 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Interesting, I see what your saying..
Re: 68 Charger Fender Tag [Re: Wolfe440] #2970535
10/04/21 07:39 PM
10/04/21 07:39 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
If it is Bondoed, and it does appear to be, you should be able to turn it over and still read the back. Unless of course they did a real "professional" job and Bondoed both sides,
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: 68 Charger Fender Tag [Re: U code RR] #2970551
10/04/21 08:40 PM
10/04/21 08:40 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
I will give that a try. Thx!
Re: 68 Charger Fender Tag [Re: Wolfe440] #2970585
10/04/21 09:45 PM
10/04/21 09:45 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
custom made tag
the top two lines codes are combined in one line to make room for the name hammer
Re: 68 Charger Fender Tag [Re: 6bblgt] #2970612
10/04/21 11:09 PM
10/04/21 11:09 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Originally Posted by 6bblgt
custom made tag
I noticed that after looking at other examples that it must be combined, had too many digits, not sure of my decoding with letters covered. Never did a 68 tag before, its different. The underneath will hopefully reveal the original.
Re: 68 Charger Fender Tag [Re: Wolfe440] #2970822
10/05/21 10:57 AM
10/05/21 10:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Would this be its license plate ?
Re: 68 Charger Fender Tag [Re: topside] #2971096
10/05/21 07:21 PM
10/05/21 07:21 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Looks legit to me ...
It takes gasoline to interest me.
