reusing valley pan/intake metal gasket #2965432
09/19/21 07:48 AM
09/19/21 07:48 AM
West Palm Beach, Florida
Copper Dart Offline OP
440 with edelbrock rpm heads and performer rpm intake
If one was going to reuse the metal intake gasket/valley pan, what sealants would advisable to avoid intake leaks? work
No paper gaskets were used previously and no air or oil leaks issues were noticed. scope
I'm leaning to a light copper coat spray on both sides to avoid the mess of silicone. up Thanks
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2965436
09/19/21 08:22 AM
09/19/21 08:22 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I would put the papers on with glued to the pan, Fel pro has a p/n that is just the 4 papers.
Re: reusing valley pan/intake metal gasket [Re: B1MAXX] #2965452
09/19/21 10:36 AM
09/19/21 10:36 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I use hylomar or permatex #2 which is a similar non hardening, gasoline and oil resistant sealer. That is for the ports. Black rtv on the corners and end rails. Do not use the right stuff...just regular old black silicone.
Re: reusing valley pan/intake metal gasket [Re: Jeremiah] #2965457
09/19/21 11:07 AM
09/19/21 11:07 AM
Kirkland, Washington
Pacnorthcuda Offline
And whatever you do….do NOT use RTV silicone on the intake runner ports! RTV and gasoline don’t play well together!
Re: reusing valley pan/intake metal gasket [Re: Pacnorthcuda] #2965551
09/19/21 08:20 PM
09/19/21 08:20 PM
So it's a NO on the spray copper coat?
I like permatex products
Copper
Mom.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Jeremiah] #2965552
09/19/21 08:39 PM
09/19/21 08:39 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree Bottom line, right there.
Master, again and still
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2965655
09/20/21 08:38 AM
09/20/21 08:38 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've reused the gasket using the same heads and intake 2-3 times without any sealant and never had a issue.
Re: reusing valley pan/intake metal gasket [Re: DusterKid] #2966288
09/22/21 10:47 AM
09/22/21 10:47 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
With metal gaskets such as the BB Mopar valley pan, there are raised embossings around the ports -- those do the primary sealing around the ports when the gasket gets compressed. The fiber supplementary gaskets are intended to take up any out-of-flat or surface imperfections... they were OE ONLY on the aluminum six-pack intakes from Ma-Mopar back in 1969... they are actually a good install for all BB intakes regardless of the intake -- cast iron or aluminum.
IF you choose to re-use the metal valley pan, be certain to install the fiber side gaskets to help seal it up. IF the embossings are crushed flat, as they likely will be, then the fiber side gaskets will help to seal.
I'm a former gasket engineer from Fel-Pro... Good luck with the install.
Re: reusing valley pan/intake metal gasket [Re: Mopar Mitch] #2966355
09/22/21 01:56 PM
09/22/21 01:56 PM
All advise very much appreciated! up
Please consider these pictures of the cylinder head marks left by the metal gasket. The marks are identical on the intake manifold too. This is why i'm considering just using a liquid or spray on sealer. The cylinder heads were not removed, only the intake and valley pan/gasket for inspection of cam lobes and tappets. Alignment couldn't have been better with just the metal gasket/valley pan and I don't think adding the thickness of 4 paper/fiber gaskets (two per side, one above and one below the metal pan/gaskets) is necessary or possibly even beneficial. Thanks in advance to those who have graduated the "been there and done that" college. grin and their shared wisdom with us students. bow beer
Copper
Mom.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2966369
09/22/21 02:32 PM
09/22/21 02:32 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
Copper
Looks like everything lines up well, any idea what the darkness inside the ports is? 4 gaskets could very well be too thick.
I've used Permatex copper spray before with no problems. Now I'm using Hylomar spray, it's as convenient and "better" than the copper spray.
My intake is too wide/sits too high to the point it barely aligns with the ports in the heads. But I still wanted something between the aluminum heads and valley pan. I hylomared 1/64" (0.015") gasket material to the head, cut out the holes for the ports with a razor. Spray hylomar on the wings of the valley pan, seal the ends, put the intake on all that. I like to seal the intake bolts as well. It's worked well so far this year drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: reusing valley pan/intake metal gasket [Re: metallicareload] #2966573
09/23/21 08:27 AM
09/23/21 08:27 AM
"Looks like everything lines up well, any idea what the darkness inside the ports is? 4 gaskets could very well be too thick." iagree
"I've used Permatex copper spray before with no problems. Now I'm using Hylomar spray, it's as convenient and "better" than the copper spray."
The darkness I think is just fuel and crankcase breather stains from the 2500 miles on it. shruggy
I agree that adding paper gaskets to the mix might do more harm than good considering the evidence marks scope work
I need to find the Hylomar spray. Would you spray both the head, intake and metal surfaces or is just a good coat on both sides of the metal gasket sufficient work
Copper
Mom.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2966687
09/23/21 01:17 PM
09/23/21 01:17 PM
Anchorage, Alaska
Anchorage, Alaska
Definitely, I think it is worth while to see what fits best on your particular engine!
I coated one side of the gasket material (the head side) I used with the spray Hylomar and stuck that down. On the valley pan I sprayed the bottom only where the valley pan sits on the heads and sprayed the top where you want it to seal to the manifold. So both sides of the head/manifold "wings" if you will twocents
440, 4-Speed, 3.54
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2966688
09/23/21 01:22 PM
09/23/21 01:22 PM
I would spray both sides of the valley pan with Hylomar up
Re: reusing valley pan/intake metal gasket [Re: Cab_Burge] #2966783
09/23/21 07:11 PM
09/23/21 07:11 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I usually use aluminum spray paint instead of copper coat. Works the same and isn't that hideous copper color If you get any on visible portions of the pan.
I don't remember confused, Is it hylomar or RightStuff that requires dynamite to get apart. hammer
Re: reusing valley pan/intake metal gasket [Re: GomangoCuda] #2966787
09/23/21 07:15 PM
09/23/21 07:15 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
RightStuff.
Re: reusing valley pan/intake metal gasket [Re: DaveRS23] #2966815
09/23/21 08:05 PM
09/23/21 08:05 PM
No one around here carries Hylomar so I'm going to use the permatex copper coat I have. Call me anal but I'm going to tape off the valley pan to avoid overspray and coating both sides of the valley pan and not the heads or intake manifold.
Copper
Mom.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2966849
09/23/21 09:25 PM
09/23/21 09:25 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Good info above this. You can verify if you have leaks on the top side of the intake by spraying carb or brake cleaner around the ports, carb base and vacuum lines if you want. I found it works best if motor is warmed up and idling.
I always block off the heat riser while I'm at it and put up with a bit slower warm up time, but I don't live in a very cold part of the US.
Re: reusing valley pan/intake metal gasket [Re: metallicareload] #2967074
09/24/21 04:08 PM
09/24/21 04:08 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
Back in the '80's I had a 440 powered dirt late model, used to cut my paper intake gaskets out of Blue Bell barbeque potato chip boxes smile
Grant
Re: reusing valley pan/intake metal gasket [Re: jbc426] #2967710
09/27/21 08:30 AM
09/27/21 08:30 AM
an8sec70cuda Offline
When using a stock style valley pan w/o the blocked crossovers, what have yall used to block them off?
I tried a cut up beer can once...burned through pretty quick, lol.
I have a couple of stock replacement valley pans that have just been sitting on the shelf that I'd like to use. I've always used the Fel-Pro 1215 w/ them blocked off already.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: reusing valley pan/intake metal gasket [Re: an8sec70cuda] #2967729
09/27/21 09:00 AM
09/27/21 09:00 AM
Apollo, PA.
Apollo, PA.
Other old valley pans/steel intake gaskets, high temp rtv'd into place.
