reusing valley pan/intake metal gasket
#2965432
09/19/21 07:48 AM
09/19/21 07:48 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
440 with edelbrock rpm heads and performer rpm intake If one was going to reuse the metal intake gasket/valley pan, what sealants would advisable to avoid intake leaks? No paper gaskets were used previously and no air or oil leaks issues were noticed. I'm leaning to a light copper coat spray on both sides to avoid the mess of silicone. Thanks Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: reusing valley pan/intake metal gasket
[Re: B1MAXX]
#2965452
09/19/21 10:36 AM
09/19/21 10:36 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I use hylomar or permatex #2 which is a similar non hardening, gasoline and oil resistant sealer. That is for the ports. Black rtv on the corners and end rails. Do not use the right stuff...just regular old black silicone.
[Re: Pacnorthcuda]
#2965551
09/19/21 08:20 PM
09/19/21 08:20 PM
Copper Dart
So it's a NO on the spray copper coat? I like permatex products Copper
[Re: Jeremiah]
#2965552
09/19/21 08:39 PM
09/19/21 08:39 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I use hylomar or permatex #2 which is a similar non hardening, gasoline and oil resistant sealer. That is for the ports. Black rtv on the corners and end rails. Do not use the right stuff...just regular old black silicone. Bottom line, right there.
Master, again and still
[Re: DusterKid]
#2966288
09/22/21 10:47 AM
09/22/21 10:47 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
With metal gaskets such as the BB Mopar valley pan, there are raised embossings around the ports -- those do the primary sealing around the ports when the gasket gets compressed. The fiber supplementary gaskets are intended to take up any out-of-flat or surface imperfections... they were OE ONLY on the aluminum six-pack intakes from Ma-Mopar back in 1969... they are actually a good install for all BB intakes regardless of the intake -- cast iron or aluminum.
IF you choose to re-use the metal valley pan, be certain to install the fiber side gaskets to help seal it up. IF the embossings are crushed flat, as they likely will be, then the fiber side gaskets will help to seal.
I'm a former gasket engineer from Fel-Pro... Good luck with the install.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2966355
09/22/21 01:56 PM
09/22/21 01:56 PM
Copper Dart
All advise very much appreciated! Please consider these pictures of the cylinder head marks left by the metal gasket. The marks are identical on the intake manifold too. This is why i'm considering just using a liquid or spray on sealer. The cylinder heads were not removed, only the intake and valley pan/gasket for inspection of cam lobes and tappets. Alignment couldn't have been better with just the metal gasket/valley pan and I don't think adding the thickness of 4 paper/fiber gaskets (two per side, one above and one below the metal pan/gaskets) is necessary or possibly even beneficial. Thanks in advance to those who have graduated the "been there and done that" college. and their shared wisdom with us students. Copper
[Re: Copper Dart]
#2966369
09/22/21 02:32 PM
09/22/21 02:32 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
All advise very much appreciated! Please consider these pictures of the cylinder head marks left by the metal gasket. The marks are identical on the intake manifold too. This is why i'm considering just using a liquid or spray on sealer. The cylinder heads were not removed, only the intake and valley pan/gasket for inspection of cam lobes and tappets. Alignment couldn't have been better with just the metal gasket/valley pan and I don't think adding the thickness of 4 paper/fiber gaskets (two per side, one above and one below the metal pan/gaskets) is necessary or possibly even beneficial. Thanks in advance to those who have graduated the "been there and done that" college. and their shared wisdom with us students. Copper Looks like everything lines up well, any idea what the darkness inside the ports is? 4 gaskets could very well be too thick. I've used Permatex copper spray before with no problems. Now I'm using Hylomar spray, it's as convenient and "better" than the copper spray. My intake is too wide/sits too high to the point it barely aligns with the ports in the heads. But I still wanted something between the aluminum heads and valley pan. I hylomared 1/64" (0.015") gasket material to the head, cut out the holes for the ports with a razor. Spray hylomar on the wings of the valley pan, seal the ends, put the intake on all that. I like to seal the intake bolts as well. It's worked well so far this year
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#2966573
09/23/21 08:27 AM
09/23/21 08:27 AM
Copper Dart
"Looks like everything lines up well, any idea what the darkness inside the ports is? 4 gaskets could very well be too thick." "I've used Permatex copper spray before with no problems. Now I'm using Hylomar spray, it's as convenient and "better" than the copper spray." The darkness I think is just fuel and crankcase breather stains from the 2500 miles on it. I agree that adding paper gaskets to the mix might do more harm than good considering the evidence marks I need to find the Hylomar spray. Would you spray both the head, intake and metal surfaces or is just a good coat on both sides of the metal gasket sufficient Copper
[Re: Copper Dart]
#2966687
09/23/21 01:17 PM
09/23/21 01:17 PM
metallicareload
Anchorage, Alaska
Definitely, I think it is worth while to see what fits best on your particular engine! I coated one side of the gasket material (the head side) I used with the spray Hylomar and stuck that down. On the valley pan I sprayed the bottom only where the valley pan sits on the heads and sprayed the top where you want it to seal to the manifold. So both sides of the head/manifold "wings" if you will
[Re: Cab_Burge]
#2966783
09/23/21 07:11 PM
09/23/21 07:11 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
I usually use aluminum spray paint instead of copper coat. Works the same and isn't that hideous copper color If you get any on visible portions of the pan. I don't remember , Is it hylomar or RightStuff that requires dynamite to get apart.
[Re: DaveRS23]
#2966815
09/23/21 08:05 PM
09/23/21 08:05 PM
Copper Dart
No one around here carries Hylomar so I'm going to use the permatex copper coat I have. Call me anal but I'm going to tape off the valley pan to avoid overspray and coating both sides of the valley pan and not the heads or intake manifold. Copper
[Re: Copper Dart]
#2966849
09/23/21 09:25 PM
09/23/21 09:25 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Good info above this. You can verify if you have leaks on the top side of the intake by spraying carb or brake cleaner around the ports, carb base and vacuum lines if you want. I found it works best if motor is warmed up and idling.
I always block off the heat riser while I'm at it and put up with a bit slower warm up time, but I don't live in a very cold part of the US.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2967710
09/27/21 08:30 AM
09/27/21 08:30 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
When using a stock style valley pan w/o the blocked crossovers, what have yall used to block them off? I tried a cut up beer can once...burned through pretty quick, lol.
I have a couple of stock replacement valley pans that have just been sitting on the shelf that I'd like to use. I've always used the Fel-Pro 1215 w/ them blocked off already.
