440 tear down? #2963714
09/13/21 05:09 PM
09/13/21 05:09 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
I'm taking apart a 1978 440 from a M/H I though it was standard bore. After taking the heads off looks like it was rebuild, .030 over, super nice cyl. walls, I don't think it has more 10,000 mi. on it. I found a windage tray, Dbl. roller timing chain and these connecting rods. Whats the scoop on the connecting rods (coating)??? I don't think it's rust thanks
Re: 440 tare down? [Re: 37dodge] #2963715
09/13/21 05:16 PM
09/13/21 05:16 PM
IMGTX Offline
IMGTX  Offline
I used to see the inside of engines that used Penzoil that color but it was the whole engine not just the rods.
I'm curious too.
Re: 440 tare down? [Re: 37dodge] #2963719
09/13/21 05:27 PM
09/13/21 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Rods are often copper plated to reduce the size of oversized bores...big end or small end or both. Oversized due to wear or faulty machining.
Re: 440 tare down? [Re: John_Kunkel] #2963727
09/13/21 05:49 PM
09/13/21 05:49 PM
bc
3
37dodge Offline OP
37dodge  Offline OP
bc
looks like the whole rod is that color ,I thought it mite be that paint for inside the block
Re: 440 tare down? [Re: 37dodge] #2963746
09/13/21 06:36 PM
09/13/21 06:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not sure what it means, but I have taken apart some mopar big blocks with rods of that color. You should also locate date stampimgs or ink on backsides of rod and mains to give you an idea of bearing dates.
Re: 440 tare down? [Re: buildanother] #2963765
09/13/21 07:13 PM
09/13/21 07:13 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Looks like a cast crank too me,most M/H eng.s had HD SP type rods & forged cranks.
Re: 440 tare down? [Re: 37dodge] #2963785
09/13/21 08:16 PM
09/13/21 08:16 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I can't help with the rod question. But I will offer this, if you're interested; You tear down an engine, not tare down an engine. And you would like to see it be standard bore, not stander bore. There are other issues in your post, too. But that is probably enough for now. This is not an attempt to be a spelling Nazi. Just offering a couple of spelling corrections should you wish to take them. And if not, well....................
Master, again and still
Re: 440 tare down? [Re: DaveRS23] #2963823
09/13/21 10:00 PM
09/13/21 10:00 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Ya, no...you don't need to be the spelling nazi. Yoo have to much to offer around here (and I sincerely appreciate that), but yore grammer corrections mite bee less then aprisheayted. Thin again, perhaps I shoodn't stir the beens.
Re: 440 tare down? [Re: Fat_Mike] #2963930
09/14/21 09:22 AM
09/14/21 09:22 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
You are right that some (maybe many) people do not take this kind of input kindly and prefer to continue typing gibberish. But once in a while, someone actually takes it to heart and comes off a little less illiterate.
Re: 440 tare down? [Re: DaveRS23] #2963932
09/14/21 09:28 AM
09/14/21 09:28 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
I've seen the recon rods come in boxes with protective coatings like that. You used to be able to buy Mellings and TRW rods, in individual boxes, and they had a coating, more than likely a rust preventative for the shelf time.
Re: 440 tare down? [Re: 37dodge] #2963941
09/14/21 09:51 AM
09/14/21 09:51 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I've seen this stuff in lifter valleys for oil control, but never on rods like that. Color looks similar, though. Sorry I'm not much help just guessing.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 440 tare down? [Re: wingman] #2964000
09/14/21 12:30 PM
09/14/21 12:30 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Take some metal polish to them...I bet they are plated in copper. Seen it many times. I know i have some small blocks laying around.
