Hemi Air Cleaner on AVS2 Carbs #2963384
09/12/21 08:14 PM
09/12/21 08:14 PM
New Port Richey, Florida
Wolfe440 Offline OP
Wolfe440  Offline OP
I have been considering using a couple of Edelbrock AVS2 carbs on a 1969 426 Hemi, stock intake manifold.
Anyone know if the stock chrome dome air filter will still fit ok?
Thx,
Wolf
Re: Hemi Air Cleaner on AVS2 Carbs [Re: Wolfe440] #2963392
09/12/21 08:36 PM
09/12/21 08:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Don't believe so as the AVS's both old and new required the larger opening Air cleaner baseplates. Could be wrong but I'm thinking not. Could buy a repop fiberglass or steel base and modify it though
EDIT:
Might also want to check the throttle blade size and spacing vs the stock intake
wink beer
Re: Hemi Air Cleaner on AVS2 Carbs [Re: TJP] #2963425
09/12/21 09:31 PM
09/12/21 09:31 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
base plate won't fit. spacing should be ok.
Re: Hemi Air Cleaner on AVS2 Carbs [Re: lewtot184] #2963430
09/12/21 10:12 PM
09/12/21 10:12 PM
Wolfe440 Offline OP
Wolfe440  Offline OP
Do you know of any alternative carbs that allow the factory air cleaner to fit?
Re: Hemi Air Cleaner on AVS2 Carbs [Re: Wolfe440] #2963455
09/12/21 11:22 PM
09/12/21 11:22 PM
MO
cdp Offline
cdp  Offline
MO
You might contact Scott at Harms Auto. He's built stock appearing carbs out of new ones. He may know the answers and also might be able to use tops of older small throat carbs on new ones. At one time, someone cast Hemi carb tops for newer eldebrock carbs.
Re: Hemi Air Cleaner on AVS2 Carbs [Re: Wolfe440] #2963456
09/12/21 11:22 PM
09/12/21 11:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I made mine fit, used the original just made rings to fit on carbs then welded them up to base. A little massaging front and back, once the top is on you cant see much anyway (66 style top) , lol, then I found the correct carbs and had to buy a new top and bottom. Now I have two complete setups, intake to air cleaner, plus the Rat Roaster intake. That’s the problem with a Hemi, don’t know when to stop buying!
I can get a pic of base tomorrow if I feel up to it, fell today and badly bruised five ribs and kneecap, can’t cough or laugh.!
Re: Hemi Air Cleaner on AVS2 Carbs [Re: cdp] #2963466
09/13/21 12:02 AM
09/13/21 12:02 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
I will check his site out, thanks!
Re: Hemi Air Cleaner on AVS2 Carbs [Re: cudaman1969] #2963468
09/13/21 12:03 AM
09/13/21 12:03 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
I appreciate the help, thank you and feel better soon!
Re: Hemi Air Cleaner on AVS2 Carbs [Re: cdp] #2963470
09/13/21 12:19 AM
09/13/21 12:19 AM
Wolfe440 Offline OP
Wolfe440  Offline OP
I found what your referring to, very interesting, I like it, will call tomorrow. Thx
http://www.harmsauto.com/parts.html
Re: Hemi Air Cleaner on AVS2 Carbs [Re: Wolfe440] #2963501
09/13/21 08:19 AM
09/13/21 08:19 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
You can buy a repop base that fits the modern carbs.
Re: Hemi Air Cleaner on AVS2 Carbs [Re: gtx6970] #2963569
09/13/21 11:54 AM
09/13/21 11:54 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
He might have what you need. https://www.tommythechryco.ca/
