strength of an OEM dana carrier and gear #2962328
09/08/21 09:04 PM
09/08/21 09:04 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i have a low mileage dana 60 carrier(sure grip) and oem 354 gear, both from an under 20k mileage Bbody automatic car. they are in a moser housing with moser axles.
how much power can these handle in a 3600lbs car in a drag strip situation ?
Re: strength of an OEM dana carrier and gear [Re: mcat4321] #2962345
09/08/21 10:56 PM
09/08/21 10:56 PM
gregsdart Offline
gregsdart  Offline
Stock gears don't like a lot of shock loads, like sidestepping a stiff clutch at high rpm, or hi rpm transbrake launches. They will live for A while. A stock dana can handle a LOT of off idle or low rpm launches. So take it easy on the launchs, or buy a spool, 35 spline race axles, and pro gears.
I had a posi go away at the track many years ago. I pulled the posi out, put a shim in it made out of a coffee can lid, wholla! Locker! Just be carefull the halves of the locker touch when you bolt it together. I put two shims in, had to remove one and all was great.
Re: strength of an OEM dana carrier and gear [Re: mcat4321] #2962346
09/08/21 10:59 PM
09/08/21 10:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
How much power are you making? Some strong components you have up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: strength of an OEM dana carrier and gear [Re: gregsdart] #2962347
09/08/21 10:59 PM
09/08/21 10:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine is a stock housing and 3.54 gears with a Dr Diff spool in a 3,700 lbs. car.
It's been 1.36 60 ft. and sees a lot of street miles. Footbrake, though.
'63 Dodge 330
11.19 @ 121 mph
Re: strength of an OEM dana carrier and gear [Re: gregsdart] #2962352
09/08/21 11:06 PM
09/08/21 11:06 PM
gregsdart Offline
gregsdart  Offline
EDIT
b][/b][quote=gregsdart]Stock gears don't like a lot of shock loads, like sidestepping a stiff clutch at high rpm, or hi rpm transbrake launches. They will live for A while. A stock dana can handle a LOT of off idle or low rpm launches. So take it easy on the launchs, or buy a spool, 35 spline race axles, and pro gears.
I had a posi go away at the track many years ago. I pulled the posi out, put a shim in it made out of a coffee can lid, wholla! Locker! Just be carefull the halves of the locker touch when you bolt it together. I put two shims in, had to remove one and all was great. [/quote
Re: strength of an OEM dana carrier and gear [Re: mcat4321] #2962353
09/08/21 11:14 PM
09/08/21 11:14 PM
What year Mopar was your rear end out of?
23 spline early axles or the later 35 spline used in 1970 and 1971 cars?
I would look at replacing the driver side carrier cap with a billet steel cap first up scope
Re: strength of an OEM dana carrier and gear [Re: Cab_Burge] #2962431
09/09/21 10:47 AM
09/09/21 10:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I would think it depends on the tires, radials are dead hook, bias slicks are easier on parts, an anvil will break eventually. With that said I can’t see a problem with that setup (4 pinion type). This was the go to rear long before the 9” became popular with gear choices. BTW a 9” inch is not any better TILL you get the aftermarket hd parts.
Re: strength of an OEM dana carrier and gear [Re: cudaman1969] #2962860
09/11/21 08:36 AM
09/11/21 08:36 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I had a 1978 F250 Dana 60 that I got with mystery miles and history. I used the stock 3.54 gear from the junk yard doner for about 5 years with a Dr. Diff spool before it started making noise and I replaced it this spring.
3740lbs with me in it, 275/60 dragradial, off the transbrake every pass. Street/strip use.. It's been a best of 1.37 60ft.
