strength of an OEM dana carrier and gear
#2962328
09/08/21 09:04 PM
09/08/21 09:04 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
i have a low mileage dana 60 carrier(sure grip) and oem 354 gear, both from an under 20k mileage Bbody automatic car. they are in a moser housing with moser axles. how much power can these handle in a 3600lbs car in a drag strip situation ?
Re: strength of an OEM dana carrier and gear
[Re: mcat4321]
#2962345
09/08/21 10:56 PM
09/08/21 10:56 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Stock gears don't like a lot of shock loads, like sidestepping a stiff clutch at high rpm, or hi rpm transbrake launches. They will live for A while. A stock dana can handle a LOT of off idle or low rpm launches. So take it easy on the launchs, or buy a spool, 35 spline race axles, and pro gears. I had a posi go away at the track many years ago. I pulled the posi out, put a shim in it made out of a coffee can lid, wholla! Locker! Just be carefull the halves of the locker touch when you bolt it together. I put two shims in, had to remove one and all was great.
[Re: gregsdart]
#2962347
09/08/21 10:59 PM
09/08/21 10:59 PM
Posts: 4,704 Wichita
GY3
Wichita
Mine is a stock housing and 3.54 gears with a Dr Diff spool in a 3,700 lbs. car.
It's been 1.36 60 ft. and sees a lot of street miles. Footbrake, though.
[Re: gregsdart]
#2962352
09/08/21 11:06 PM
09/08/21 11:06 PM
gregsdart
EDIT
b][/b][quote=gregsdart]Stock gears don't like a lot of shock loads, like sidestepping a stiff clutch at high rpm, or hi rpm transbrake launches. They will live for A while. A stock dana can handle a LOT of off idle or low rpm launches. So take it easy on the launchs, or buy a spool, 35 spline race axles, and pro gears. I had a posi go away at the track many years ago. I pulled the posi out, put a shim in it made out of a coffee can lid, wholla! Locker! Just be carefull the halves of the locker touch when you bolt it together. I put two shims in, had to remove one and all was great. [/quote
[Re: mcat4321]
#2962353
09/08/21 11:14 PM
09/08/21 11:14 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
What year Mopar was your rear end out of? 23 spline early axles or the later 35 spline used in 1970 and 1971 cars? I would look at replacing the driver side carrier cap with a billet steel cap first ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
