383 Non-A/C Alternator Out of Line #2959717
08/31/21 09:37 PM
08/31/21 09:37 PM
Detroit, Mi
michiganhotrod1 Offline OP
Detroit, Mi
Hello;
After having two alternator - water pump belts fail recently, someone pointed out that my alternator did not line up with the fan and crank pulleys.
The car is 70 Challenger R/T, 383, and stock. I've owned it for a while, and it was a reasonable unmolested car when I got it.
See the photos for how the brackets are installed now, they appear from the web to be the correct ones in correct location. The belt comes very close to the bolt on top right bracket hole, and the belt failed there; I've since installed a thinner bolt, but clearance is still minimal.
To get the alternator in line, I added a couple of thick washers and a slightly longer spacer. It works, but I am curious why I had to jerry rig it since I don't think it was built this way.
Any suggestions?
Thanks,
Mark
Re: 383 Non-A/C Alternator Out of Line [Re: michiganhotrod1] #2959771
09/01/21 03:36 AM
09/01/21 03:36 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
To me, it looks like the rear alternator spacer on that top pivot bolt is too short.
That would cause the alternator to sit too far back closer to the cylinder head.
Spacing it forward with a longer spacer would move the alternator forward and get the belt to align properly.
Having it angled back like that would make it end up closer to that top bolt since the whole thing is out of position.
Re: 383 Non-A/C Alternator Out of Line [Re: SNK-EYZ] #2959941
09/01/21 03:14 PM
09/01/21 03:14 PM
Torq37 Offline
Torq37  Offline
I'm working on a similar problem. Anybody have the correct length for the spacer sleeve that goes between the head and alternator?
Re: 383 Non-A/C Alternator Out of Line [Re: Torq37] #2959943
09/01/21 03:21 PM
09/01/21 03:21 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
70 RR 383. Hard to get a tape in there.....looks like 1 5/8 for the small one and 2 1/2 for large
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 383 Non-A/C Alternator Out of Line [Re: JMCFAN] #2960278
09/02/21 12:02 PM
09/02/21 12:02 PM
moparx Offline
moparx  Offline
i just measured a 69 383 and got 1 5/8" for the small one, and 2 3/8" for the large one.
however, the [moveable] alternator bushing in the rear ear sticks out 1/8" into the space the large spacer occupies.
beer
Re: 383 Non-A/C Alternator Out of Line [Re: moparx] #2960288
09/02/21 12:38 PM
09/02/21 12:38 PM
VA
dragon slayer Offline
VA
1 2.355” Spacer between alternator ears 2206449 (2.35)
1 1.115” Spacer to water pump housing 2206450 (1.11)
1 1.550” Spacer to head behind alternator 2206448 (1.55)
