8-3/4 availability #2958700
08/29/21 02:28 PM
08/29/21 02:28 PM
Batavia,Ohio,
Moparmick Offline OP
Batavia,Ohio,
Anyone know if a 8-3/4 rear was available on a 69 satellite w/318? is a 4dr car ,was this standard for this car?
Re: 8-3/4 availability [Re: Moparmick] #2958705
08/29/21 02:36 PM
08/29/21 02:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Options and / or equipment can determine the rear end type.
So how is the car equipped?
I pulled one from a 1969 Coronet 4-door years ago that had been wrecked, FAA fleet car with a 318 & it had an 8 3/4".
I did not know anything about codes then, I was just a kid.
Re: 8-3/4 availability [Re: Alaskan_TA] #2958708
08/29/21 02:47 PM
08/29/21 02:47 PM
Batavia,Ohio,
Batavia,Ohio,
Auto w/air is all I know for now considering for purchase waiting on call back haven't seen in person 4dr car
Re: 8-3/4 availability [Re: Moparmick] #2958839
08/29/21 09:07 PM
08/29/21 09:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Seen many over the years, don't think anything smaller was used ? But could be wrong on that shruggy beer
Re: 8-3/4 availability [Re: TJP] #2958886
08/29/21 11:55 PM
08/29/21 11:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The odds are it still had an 8 3/4 in 69, but once it got into the early 70s, the odds got smaller. By late 72, there were probably better odds it had an 8 1/4 then an 8 3/4. I believe 74 was the last car production 8 3/4. Choices were 7 1/4, 8 1/4 or 9 1/4 after 74.
I had a 72 Satellite Sebring Plus 2 door 318, it had a 904 and an 8 1/4. Gene
Re: 8-3/4 availability [Re: poorboy] #2958991
08/30/21 12:13 PM
08/30/21 12:13 PM
moparx Offline
moparx  Offline
i think pickup and van last had 8 3/4's around 74 as well. i don't recall any 75 & up, including 4x4's, having 8 3/4's.
my brother had a 72 sebring plus with a 400/727 that had an 8 3/4 rear, while my sister had an almost identical 73 sebring plus with a 318/904 that had an 8 1/4 rear.
beer
Re: 8-3/4 availability [Re: moparx] #2959074
08/30/21 03:55 PM
08/30/21 03:55 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
In 69 they started putting 8 1/4's in B Bodies with 318 auto setups unless it had some type of axle upgrade option, if it was a 318 with manual trans I believe it would have had an 8 3/4 axle as standard.
Re: 8-3/4 availability [Re: chargerbr549] #2959175
08/30/21 08:39 PM
08/30/21 08:39 PM
I saw a non 8 3/4 rear end in a slant six automatic1970 Charger in 1972 or 1973, it had the removeable inspection plate like the 7 1/4 and 8 1/4 had, I didn't know about the 8 1/4 rear ends then and ASSUME it was a 7 1/4 shruggy
Please take this for what it is worth, not much shruggy
Never say Mopar never did that shock whistling grin
