Removing (DODGE BALLS) spray paint from my truck #2957854
08/27/21 02:38 AM
08/27/21 02:38 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
So I did a thing today, and found my new winter beater with a heater.
However it has some interesting custom paint that I would like to remove.
30 years ago I would have proudly driven this as is, but my more mature self understands that the neighbors may not like this sitting out in plain view. And I don't need to draw attention to myself while driving down the road.
The paint is fully cured, it's been on there for 8 months or longer.
I'm not worried about the finish under the paint, the picture speaks for itself on that.
Eventually a quicky weekend garage spray, or rattle can job in olive drab or camo will be done,
I'm hoping a solvent will be able to remove this. I no longer have the tools, or physical ability to DA the entire truck.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Removing spray paint from my truck [Re: hp383] #2957858
08/27/21 02:55 AM
08/27/21 02:55 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
You wont believe this and I Did NOT till We cleaned a nice Dark Blue Econoline Van . EZ -Off oven Cleaner , I KNOW better stuff avaiable today , But it worked , MINT . drive Buddy is a body shop guy , Sprayed on a tee-shirt or old cotton rag , then Gently ONLY work on the Old paint . We had that Econoline Ready for a New home in 24 Hours . Wear gloves . Old formula was stronger , but it was NOT that long ago . I thought he was Nuts , till I saw it work . Any other Moparts cleaner Tidbits ? R
Re: Removing spray paint from my truck [Re: 1969ronnie] #2957863
08/27/21 03:08 AM
08/27/21 03:08 AM
1969ronnie Offline
1969ronnie  Offline
And HP , the advertising paint , which should be stronger than your paint , we removed was 8 YEARS old , NOT 8 months old ! wave I agree , nice truck , that stuff should clean up with a little elbow grease . dakota Show some pics AFTER it's mint next week ! R boogie
Re: Removing (DODGE BALLS) spray paint from my truck [Re: hp383] #2957877
08/27/21 07:40 AM
08/27/21 07:40 AM
tboomer Online work
tboomer  Online Work
Shouldn't it read "Mushy Blue Balls"? laugh2
Re: Removing (DODGE BALLS) spray paint from my truck [Re: hp383] #2957883
08/27/21 08:08 AM
08/27/21 08:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have read that to get off spray paint “tagging” by gang “artists”
one technique is to heat the spray paint up with an electric heat gun
then shock stress the spray paint by touching it with solid dry ice
causing it to contract and break off at the layer between the 2 paints.
I have not tried this myself.
I have been amazed more than once in the past what a help dry ice is for certain uses.
Someone should do a youtube on “amazing things that you did not know dry ice could do”
I now own 2 UV-C disinfecting battery powered light “wands”
one by Brookstone,
another by the PureMobile division of Vivitar, Sakar International.
I wonder if Ultraviolet C light could degrade the spray paint after a certain time?
Mask off the original paint.
The electric arc of welding puts off intense UV light.
Re: Removing (DODGE BALLS) spray paint from my truck [Re: 360view] #2957885
08/27/21 08:16 AM
08/27/21 08:16 AM
RWG75
RWG75
Looks like an 80 grit problem to me. Maybe just some tractor paint and a throw away roller to cover it up.
Re: Removing spray paint from my truck [Re: 1969ronnie] #2957891
08/27/21 08:56 AM
08/27/21 08:56 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree That's what I use, too. But it has to be EZ Off. The other cheap brands just don't work as well. And keep it off the trim.
Master, again and still
Re: Removing spray paint from my truck [Re: DaveRS23] #2957901
08/27/21 09:16 AM
08/27/21 09:16 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Berkebile 2+2 will make quick work of that.
Re: Removing spray paint from my truck [Re: DaveRS23] #2957903
08/27/21 09:20 AM
08/27/21 09:20 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
X3. I used EZ Off to take the old registration numbers off of my boat (painted on), but that was on gel coat. It yellowed the gel coat, but vinegar neutralized it and it came back to white "like it never happened."
Re: Removing (DODGE BALLS) spray paint from my truck [Re: hp383] #2957922
08/27/21 09:59 AM
08/27/21 09:59 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Acetone, Carb clean come to mind. Goop off but it's a bit pricey. If you have a body shop nearby maybe they have some leftover paint(s) they can just blow over the "graphics". a couple of other option's: hit the local Home depot / lowes etc. They usually have mixed paint that was wrong for whatever reason, grab a roller as previously mentioned and go for it, or walmart's cheapest spray bomb paint
twocents beer
Re: Removing (DODGE BALLS) spray paint from my truck [Re: TJP] #2957924
08/27/21 10:05 AM
08/27/21 10:05 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Xylene, works great, cheap, but wear gloves, it's hot stuff. I think goof off is ~ 98% Xylene anyway?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Removing (DODGE BALLS) spray paint from my truck [Re: 3hundred] #2957935
08/27/21 10:34 AM
08/27/21 10:34 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
One of my bud's truck was vandalized with black spray bomb. Took it off with aerosol brake cleaner. Finish was BC/CC and the cleaner didn't touch it.
Re: Removing (DODGE BALLS) spray paint from my truck [Re: tboomer] #2957949
08/27/21 10:58 AM
08/27/21 10:58 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
There is a reference to my past that I haven't heard in a very long time!
LOL 😆🤣😂
Re: Removing (DODGE BALLS) spray paint from my truck [Re: hp383] #2958024
08/27/21 03:35 PM
08/27/21 03:35 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Wax and grease remover might soften it up.
Clay bars will take off cheap paint if it's not too thick.
They make a super fine steel wool too.
Re: Removing spray paint from my truck [Re: DaveRS23] #2958094
08/27/21 07:59 PM
08/27/21 07:59 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Add me to this list. EZ Off. Don't let it get to the trim though. May take a couple of applications, I like to remove the "art work" it in layers.
Re: Removing (DODGE BALLS) spray paint from my truck [Re: TJP] #2958099
08/27/21 08:22 PM
08/27/21 08:22 PM
IL us
I
ink Offline
ink  Offline
I
IL us
ez off x4
Re: Removing (DODGE BALLS) spray paint from my truck [Re: ink] #2958103
08/27/21 08:38 PM
08/27/21 08:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by ink
ez off x4
Wow, I would've thought that would eat the paint underneath as well. EZ-Off was pretty nasty stuff years back.
So how do you guys use it as a paint remover ?
Spray it on, wipe off the offending layers and rinse with water ?
I'm assuming you're all referring to spray bomb paint ?
shruggy
Re: Removing (DODGE BALLS) spray paint from my truck [Re: TJP] #2958153
08/28/21 12:14 AM
08/28/21 12:14 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
My recommendation? Go find some mud and have fun. This method also works great to hide rust and mismatched paint. biggrin
John
Re: Removing (DODGE BALLS) spray paint from my truck [Re: TJP] #2958186
08/28/21 03:52 AM
08/28/21 03:52 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
ez off x4
shruggy
I removed old hand painted lettering from an old truck with EZ Off. Spray the E Z Off onto the door lettering, wait a few seconds for the lettering paint to bubble, and wipe it off. Repeat until the lettering is gone, hose off the truck body.
If the lettering was there for a long time, sometimes the paint around the lettering was faded, and after the lettering was removed, you could still see where it was because the surrounding paint was faded. Often a bit of buffing would match up the colors better, but then the entire door (or where the buffing was done) looked better then other parts of the faded paint. Some colors faded worse then other colors. Gene
Re: Removing (DODGE BALLS) spray paint from my truck [Re: poorboy] #2958211
08/28/21 07:56 AM
08/28/21 07:56 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have no recommendations on removal, but have to say that custom work is amazing. laugh2
You could totally get those reproduced in vinyl so you could reinstall them at a later date!
