Removing (DODGE BALLS) spray paint from my truck
#2957854
08/27/21 02:38 AM
08/27/21 02:38 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
So I did a thing today, and found my new winter beater with a heater. However it has some interesting custom paint that I would like to remove. 30 years ago I would have proudly driven this as is, but my more mature self understands that the neighbors may not like this sitting out in plain view. And I don't need to draw attention to myself while driving down the road.
The paint is fully cured, it's been on there for 8 months or longer.
I'm not worried about the finish under the paint, the picture speaks for itself on that.
Eventually a quicky weekend garage spray, or rattle can job in olive drab or camo will be done,
I'm hoping a solvent will be able to remove this. I no longer have the tools, or physical ability to DA the entire truck.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Removing (DODGE BALLS) spray paint from my truck
[Re: 360view]
#2957885
08/27/21 08:16 AM
08/27/21 08:16 AM
RWG75
RWG75
Looks like an 80 grit problem to me. Maybe just some tractor paint and a throw away roller to cover it up.
[Re: TJP]
#2957924
08/27/21 10:05 AM
08/27/21 10:05 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Goop off but it's a bit pricey. Xylene, works great, cheap, but wear gloves, it's hot stuff. I think goof off is ~ 98% Xylene anyway?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2957935
08/27/21 10:34 AM
08/27/21 10:34 AM
Posts: 10,738 North Dakota
6PakBee
North Dakota
One of my bud's truck was vandalized with black spray bomb. Took it off with aerosol brake cleaner. Finish was BC/CC and the cleaner didn't touch it.
[Re: tboomer]
#2957949
08/27/21 10:58 AM
08/27/21 10:58 AM
hp383
State of Confusion
Shouldn't it read "Mushy Blue Balls"? There is a reference to my past that I haven't heard in a very long time! LOL 😆🤣😂
[Re: hp383]
#2958024
08/27/21 03:35 PM
08/27/21 03:35 PM
Posts: 20,677 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Wax and grease remover might soften it up.
Clay bars will take off cheap paint if it's not too thick.
They make a super fine steel wool too.
[Re: TJP]
#2958099
08/27/21 08:22 PM
08/27/21 08:22 PM
Posts: 404 IL us
ink
IL us
[Re: ink]
#2958103
08/27/21 08:38 PM
08/27/21 08:38 PM
Posts: 15,445 Omaha Ne
TJP
Omaha Ne
Wow, I would've thought that would eat the paint underneath as well. EZ-Off was pretty nasty stuff years back. So how do you guys use it as a paint remover ? Spray it on, wipe off the offending layers and rinse with water ? I'm assuming you're all referring to spray bomb paint ?
[Re: TJP]
#2958186
08/28/21 03:52 AM
08/28/21 03:52 AM
Posts: 10,605 Freeport IL USA
poorboy
Freeport IL USA
Wow, I would've thought that would eat the paint underneath as well. EZ-Off was pretty nasty stuff years back. So how do you guys use it as a paint remover ? Spray it on, wipe off the offending layers and rinse with water ? I'm assuming you're all referring to spray bomb paint ? I removed old hand painted lettering from an old truck with EZ Off. Spray the E Z Off onto the door lettering, wait a few seconds for the lettering paint to bubble, and wipe it off. Repeat until the lettering is gone, hose off the truck body. If the lettering was there for a long time, sometimes the paint around the lettering was faded, and after the lettering was removed, you could still see where it was because the surrounding paint was faded. Often a bit of buffing would match up the colors better, but then the entire door (or where the buffing was done) looked better then other parts of the faded paint. Some colors faded worse then other colors. Gene
[Re: poorboy]
#2958211
08/28/21 07:56 AM
08/28/21 07:56 AM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I have no recommendations on removal, but have to say that custom work is amazing. You could totally get those reproduced in vinyl so you could reinstall them at a later date!
