///A-body+fuel cell (update)\\\\\\\\\ #295768
04/21/09 09:36 PM
04/21/09 09:36 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
Well i finally got my fuel cell in my car. I think it looks kind of looks like crap. But i cant fab to save my life. So it will have to do i guess. I used a sheet of 1/8 aluminum and pop riveted it to my trunk floor.I still have to figure out something to cover up the little hole in front of the fuel cell wear the fuel lines come out.If i put the fuel cell all the way flush with the hole i cut. You can almost not get a fuel line on the cell fittings. Here is a pick of the cell. good or bad tell me what you think. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295769
04/21/09 09:45 PM
04/21/09 09:45 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Bobby. it looks OK to me. You saw what my new POS looks like at MoKan. Good job! Like Bob Glidden once said"These cars don't have to look pretty. Just run fast."
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295770
04/21/09 09:45 PM
04/21/09 09:45 PM
mopar65 Offline OP
mopar65  Offline OP
Here is how i ended up mounting my fuel pump. I tried taking a pick but my camera battery died on me so this is the only good one i have right now. But I have a concern about wear i mounted my fuel pump. going by my crappy picture do you see a problem of the rear leaf spring shackle hitting my fuel line if my car ever lunches real hard? I just stuck a short piece of hose on there to see how it would look and have not mounted it sold yet.thanks for all the help guys. mopar65
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295771
04/21/09 09:46 PM
04/21/09 09:46 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You could use the material that you cut out and make a box to cover it. It doesn't need to be covered.
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295772
04/21/09 09:59 PM
04/21/09 09:59 PM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
Thats not bad looking at all Bobbie. With the trunk closed going 120 MPH who's going to see it???
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: PS Arrow] #295773
04/21/09 10:22 PM
04/21/09 10:22 PM
mopar65 Offline OP
mopar65  Offline OP
thanks for all the kind words guys. I just wish i could do a better job with stuff like that is all. When i was building up my 65 plymouth. I had my buddy ramcharger do all the fab work for me. He did awesome work i thought. sorry for getting off track but does any body care to give me some input about my second question or is the picture just to crappy to see. I will try and get a better pick for you guys tomorrow. here is a underneath pick of the cell. John looks like you got the arrow going good thanks Mopar65
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295774
04/21/09 11:11 PM
04/21/09 11:11 PM
rowin4 Offline
rowin4  Offline
A couple things you might consider is moving the pump to the side of the frame, thats how mine is and it worked out well. The other is that you should have a filter mounted before the pump. Mount the filter on the frame also. #8an braided line will work fine. A filter isn't cheep but it's cheeper than a pump or carb needle and seats.
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: rowin4] #295775
04/21/09 11:20 PM
04/21/09 11:20 PM
mopar65 Offline OP
mopar65  Offline OP
HI thanks for the advice. Do you have a pick of how you mounted your pump? also if you look real hard past my fuel pump you will see that i have a fuel filter also. But it is hard to see. I will be using dash 8 lines and fittings compared to my 65 plymouth this dart does not have have a hole lot of room to mount stuff back there.If i did not have leef springs i would have tons of room. Thanks Mopar65
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295776
04/21/09 11:31 PM
04/21/09 11:31 PM
rowin4 Offline
rowin4  Offline
Nope, no pic's , hows your filter mounted ? [ can't see it ] in line or bracket mount? Mine had leafs when i first installed them, 90 out of the cell to the inside frame a short bend to a bracket mounted spin on type filter then a short 6"-8" to the holley blue pump.
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: rowin4] #295777
04/22/09 07:30 AM
04/22/09 07:30 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I've just redone mine, i dropped the tapered part of the cell through the floor and fitted a small angle in front to cover any daylight that was showing through.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: ///A-body+fuel cell (update)\\\\\\\\\ [Re: mopar65] #295778
04/22/09 09:02 AM
04/22/09 09:02 AM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
Bobby can't you just run it along the frame rail, up and over the rear? I guess the angle of the pic makes it hard to really judge where the obstruction may be. Thanks Bobby, the Arrow is coming along, it is a blast to cruise, cant wait to get some slicks and really see what it will do.
John
