sealing oil dipstick #2955997
08/21/21 01:53 PM
08/21/21 01:53 PM
birdtracker Offline OP
first time vaccum pump user and was looking for a good idea for the dipstick? thanks. Birdtracker
Re: sealing oil dipstick [Re: birdtracker] #2956002
08/21/21 02:08 PM
08/21/21 02:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Look for a dipstick with a seal, pretty common on late-model stuff.
Obviously long enough you can calibrate it.
Re: sealing oil dipstick [Re: birdtracker] #2956025
08/21/21 03:37 PM
08/21/21 03:37 PM
AndyF Offline
AndyF  Offline
If you want to eliminate the vacuum leak then you'll need to buy a sealed dipstick.
Re: sealing oil dipstick [Re: AndyF] #2956068
08/21/21 05:45 PM
08/21/21 05:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Drill and tap the hole and plug it. Why do you need a dipstick?
Calibrate the pan before installing it. Calculate filters, accusumps, etc. Put oil in it less a quart or so and race it.
Re: sealing oil dipstick [Re: CMcAllister] #2956083
08/21/21 06:40 PM
08/21/21 06:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine uses a late model Jeep dipstick and tube cut down. It O ring seals.
Doug
Re: sealing oil dipstick [Re: birdtracker] #2956177
08/22/21 12:06 AM
08/22/21 12:06 AM
I use a vacuum cap on my stock dipstick tube with a small hose clamp up scope wrench
Re: sealing oil dipstick [Re: Cab_Burge] #2956180
08/22/21 12:26 AM
08/22/21 12:26 AM
New York, USA
Chargerfan68 Offline
New York, USA
I used a Milodon billet/braided dipstick/tube on my lowdeck stroker and with vac pump, and reached 20+ “ vacuum before adjusting down to lower levels. It sealed up very well. I think it was pn 22070
Re: sealing oil dipstick [Re: Chargerfan68] #2956187
08/22/21 01:58 AM
08/22/21 01:58 AM
Is that the one that has two O rings on the male part that sticks into the block?
Re: sealing oil dipstick [Re: Cab_Burge] #2956367
08/22/21 04:13 PM
08/22/21 04:13 PM
New York, USA
New York, USA
I don’t think this one has oring on the part that goes into block, but I used the Right Stuff to seal it up well. The dipstick does have oring.
