Re: sealing oil dipstick
[Re: birdtracker]
#2956025
08/21/21 03:37 PM
08/21/21 03:37 PM
Posts: 31,046 Oregon
AndyF
first time vaccum pump user and was looking for a good idea for the dipstick? thanks. Birdtracker If you want to eliminate the vacuum leak then you'll need to buy a sealed dipstick.
[Re: AndyF]
#2956068
08/21/21 05:45 PM
08/21/21 05:45 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Drill and tap the hole and plug it. Why do you need a dipstick?
Calibrate the pan before installing it. Calculate filters, accusumps, etc. Put oil in it less a quart or so and race it.
[Re: Cab_Burge]
#2956180
08/22/21 12:26 AM
08/22/21 12:26 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I used a Milodon billet/braided dipstick/tube on my lowdeck stroker and with vac pump, and reached 20+ “ vacuum before adjusting down to lower levels. It sealed up very well. I think it was pn 22070
[Re: Chargerfan68]
#2956187
08/22/21 01:58 AM
08/22/21 01:58 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
Is that the one that has two O rings on the male part that sticks into the block?
[Re: Cab_Burge]
#2956367
08/22/21 04:13 PM
08/22/21 04:13 PM
Chargerfan68
New York, USA
Is that the one that has two O rings on the male part that sticks into the block? I don’t think this one has oring on the part that goes into block, but I used the Right Stuff to seal it up well. The dipstick does have oring.
