Page 1 of 3 1 2 3
Electrical draw on new resto,,,,where to start,,, #2956040
08/21/21 04:55 PM
08/21/21 04:55 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Newly restored 70 RR, Runs great,,,,but, I have a 5.4 amp draw on battery when measured at the neg battery terminal when car is off, Have pulled individual fuses with no change, where should I start? Freshly painted....so grounding issue?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956050
08/21/21 05:20 PM
08/21/21 05:20 PM
Andrewh Offline
Andrewh  Offline
restored, or resto modded?
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956051
08/21/21 05:21 PM
08/21/21 05:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Car all stock build?
If so, ck the alternator
Glovebox light, key in cylinder light etc etc
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956053
08/21/21 05:25 PM
08/21/21 05:25 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree
Unplugging harnesses until it goes away will help narrow it down
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956063
08/21/21 05:41 PM
08/21/21 05:41 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
5 amp is a lot. That's no simple light that's on.
First suspect would be the alternator not being wired correctly.
Re: Electrical draw on new resto,,,,where to start,,, [Re: BigBlockMopar] #2956070
08/21/21 05:56 PM
08/21/21 05:56 PM
GA
roadrunninMark Offline
GA
Also check starter relay / starter, things that are wired "hot most of the time" w/o the key on. If no luck there, pull each fuse one at a time. Should be able to check draw at battery or jumping the fuse blade ends at the box to see if there is draw or not.
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956074
08/21/21 06:04 PM
08/21/21 06:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Disconnect the wire from the alternator BAT lug.
Re: Electrical draw on new resto,,,,where to start,,, [Re: roadrunninMark] #2956097
08/21/21 07:09 PM
08/21/21 07:09 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I did pull each fuse....no change
Re: Electrical draw on new resto,,,,where to start,,, [Re: John_Kunkel] #2956098
08/21/21 07:10 PM
08/21/21 07:10 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
What should I look for there,,,,?
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956118
08/21/21 08:38 PM
08/21/21 08:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
if the draw gores away you may have an alternator partially shorting. DO KEEP THE BATTERY DISCONNECTED while the car is unattended beer
Re: Electrical draw on new resto,,,,where to start,,, [Re: TJP] #2956239
08/22/21 11:14 AM
08/22/21 11:14 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Couple of checks this morning
Batt lead to Alternator pulled-
Headlight Switch
High/low beam switch.
Draw still there,,,,with a fully charged battery it is 7 amps,,,,,,
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956240
08/22/21 11:22 AM
08/22/21 11:22 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Sure there's nothing else wired hot through a switch? Fog lights?
Facts are stubborn things.
Re: Electrical draw on new resto,,,,where to start,,, [Re: larrymopar360] #2956243
08/22/21 11:34 AM
08/22/21 11:34 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
No all stock build,,,,and all new harness from Year One ( M&H)
Re: Electrical draw on new resto,,,,where to start,,, [Re: larrymopar360] #2956245
08/22/21 11:35 AM
08/22/21 11:35 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What specifically are you using to measure the current? That seems high with no light visibly on and no motors running. If this is a stock setup what are the high current consuming devices, assuming that something hasn't failed?
1) ignition
2) A/C clutch
3) heater blower motor
4) headlights
5) rear window defogger
6) power windows
7) horn
8) windshield wiper
There just aren't that many devices that can draw that kind of current constantly and not have some kind of problem show up.
Re: Electrical draw on new resto,,,,where to start,,, [Re: 6PakBee] #2956253
08/22/21 12:09 PM
08/22/21 12:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1) ignition
2) A/C clutch
4) headlights
6) power windows
7) horn
8) windshield wiper
Agreed that kind of draw is huge and not see anything on. Nothing on these cars back then had a key off draw except maybe time delay lighting for key switch
Re: Electrical draw on new resto,,,,where to start,,, [Re: gtx6970] #2956261
08/22/21 12:20 PM
08/22/21 12:20 PM
Andrewh Offline
Andrewh  Offline
I don't think you answered. is this a stock restoration or have you modded it? any modern features or added items that wouldn't be stock for that year?
how are you measuring amps drawn?
Re: Electrical draw on new resto,,,,where to start,,, [Re: Andrewh] #2956281
08/22/21 12:52 PM
08/22/21 12:52 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Stock resto..with all new harness from Year One ( M&H) .only mod would the the upgraded digital tach added to the original Tic Toc tac which doesnt work,.....
Measuring with Fluk meter at the neg battery cable
Re: Electrical draw on new resto,,,,where to start,,, [Re: 6PakBee] #2956285
08/22/21 12:55 PM
08/22/21 12:55 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
1) ignition works fine.....?
2) A/C clutch none
3) heater blower motor- have not check yet....its not running
4) headlights pulled switch cable-no change
5) rear window defogger none
6) power windows none
7) horn works fine
8) windshield wiper have not checked motor is a Jules rebuild...but does not work...will pull switch cable to test next
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956289
08/22/21 12:57 PM
08/22/21 12:57 PM
BDW Offline
BDW  Offline
I'd start pulling each harness at the firewall (engine side) to see when it goes away.
Re: Electrical draw on new resto,,,,where to start,,, [Re: JMCFAN] #2956297
08/22/21 01:10 PM
08/22/21 01:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
2) A/C clutch none
7) horn works fine
You are making assumptions when you say "works fine". Something is not working fine and until you physically disconnect EACH item on the list and check you cannot assume it "works fine".
For example, your ignition could very well draw 7 amps in use, but is still drawing current when it should be off. So while it make "work fine" in start and run, it should not be drawing current at all in off. Until you disconnect it you won't know.
Page 1 of 3 1 2 3
