Small Block, Meziere Pump, Radiator Fan Combo
#2954170
08/16/21 06:57 AM
08/16/21 06:57 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Is anyone out there running a Radiator and Fan combo for an A-body that clears the meziere pump with a small block? My current setup has worked for a long time but I would like tp upgrade it. I see lots of people make a radiator and electric fan combo but some I see either have cheap fans, or the dimensions won't clear the Meziere pump. Kind of looking for a bolt in deal before Drag Week. Thanks for any info.
I have looked at Becool(which might work but to expensive), I have an email into cold case radiator, and one or two others I can't remember. I can look at the Champion setup and tell that it won't clear the pump.
Its an unlikely find this close to drag week but worth an ask. I am worried about reliability of my current hacked up Dodge Intrepid fans more than I am over heating.
68 Barracuda Formula S 340
Re: Small Block, Meziere Pump, Radiator Fan Combo
[Re: Bad340fish]
#2954171
08/16/21 07:07 AM
08/16/21 07:07 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
The Chevrolet SSR fan and shroud package is about the narrowest I could find , and it fits the core nicely. But I am using a remote pump and shoving water into the center core plugs , so the pump isn't hanging off the front of the motor. If you have 4" from pump to radiator , it will be close to right. I seem to recall it being 3 5/8 " thick.
[Re: J_BODY]
#2954223
08/16/21 10:59 AM
08/16/21 10:59 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
I run one of these fan setups, with a universal northern/summit radiator. I run chevrolet style with passenger lower/drivers upper, but I'd consider a double pass if you can run both on the passenger side. https://www.universalpartsinc.com/shopping/productDetails.aspx?i=750831&c=10328
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#2954417
08/16/21 06:57 PM
08/16/21 06:57 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I will be tackling this problem soon , it will have to be a 1 off custom piece it appears to fit it in nicely ( that Meziere snout is long )
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: Bad340fish]
#2954563
08/17/21 09:17 AM
08/17/21 09:17 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Its an unlikely find this close to drag week but worth an ask. I am worried about reliability of my current hacked up Dodge Intrepid fans more than I am over heating. mine is a csr pump put it clears i would put pics but its a pain in the butt for lol
[Re: Bad340fish]
#2954700
08/17/21 02:10 PM
08/17/21 02:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I used a Champion crossflow radiator and shroud for a early big block Camaro. Also you can pick up about 3/4" by milling the recess off the timing cover and and not using the Meziere block off plate.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2954758
08/17/21 04:48 PM
08/17/21 04:48 PM
Bad340fish
Tulsa OK
That looks really good, my Dad and I were just talking about the timing cover modification this morning. I don't have time to rework much stuff before Drag Week so I ordered a Delta Pag 18" 4000CFM fan. Its only 2.1" thick at the edge and 2.7" in the middle. Not the cheapest option but I have wanted one for awhile because I can control its speed with my Megasquirt.
[Re: Bad340fish]
#2962711
09/10/21 01:34 PM
09/10/21 01:34 PM
Bad340fish
Tulsa OK
Cutting it close with the fan coming in last night. Its in and working but wired ugly due to time. Haven't driven the car yet but I can't imagine this not being better than what I had. It moves some air! 4000CFM and its not even that loud. The fan controller they offer is nice but I will probably move it to being controlled by my EFI to clear up some mess once drag week is over.
