70 E-body console with 518 trans and stock type shifter? #2953592
08/13/21 10:14 PM
08/13/21 10:14 PM
California
BigDaddy440 Offline OP
California
Any vendor make a kit or stock style shifter to use in a factory 70 E-body auto console setup with a 4speed auto like the 518 Trans?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BigDaddy440] #2953600
08/13/21 10:42 PM
08/13/21 10:42 PM
BDW Offline
BDW  Offline
I used the same factory shifter when I converted from 727 to 518.
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BDW] #2953616
08/13/21 11:56 PM
08/13/21 11:56 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
You just need a way to turn the OD on and off. Shifter is the same otherwise. Might have to mod the floor, however.
Re: 70 E-body console with 518 trans and stock type shifter? [Re: Jim_Lusk] #2953630
08/14/21 01:42 AM
08/14/21 01:42 AM
California
California
Thank you guys, that sense!
Hope you're well Jim!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BigDaddy440] #2953634
08/14/21 05:59 AM
08/14/21 05:59 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
https://transmissioncenter.net/shop/727-to-518-transmission-swap-information/
Re: 70 E-body console with 518 trans and stock type shifter? [Re: Moparite] #2953668
08/14/21 10:13 AM
08/14/21 10:13 AM
BDW Offline
BDW  Offline
Everything you need to know for 518 E-body swap here:
http://www.cuda-challenger.com/cc/index.php?topic=84774.0
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BigDaddy440] #2953710
08/14/21 01:13 PM
08/14/21 01:13 PM
Maryland
mrob Offline
mrob  Offline
Maryland
Bigdaddy,
I've done the A-518 swap in my Cuda and kept the stock Slap-Stick shifter. Let me point one thing out: the lower pivot for the shifter linkage won't bolt to the tailshaft of the A-518 (like it does on the A-727). So you'll need to fabricate a pivot and find a good place to mount it. You'll see that in one of the links. Just thought I'd mention that up front and save you some reading.
Good luck
Re: 70 E-body console with 518 trans and stock type shifter? [Re: mrob] #2953769
08/14/21 04:19 PM
08/14/21 04:19 PM
moparx Offline
moparx  Offline
has anyone swapped to a 518, then modified the valve body with a trans -go TFOD-3 kit, which is supposed to make the 518 a manual valve body ?
if so, how did it work out ? how did it work if you used a slapstick shifter ?
TIA as always ! bow
beer
Re: 70 E-body console with 518 trans and stock type shifter? [Re: moparx] #2953808
08/14/21 06:05 PM
08/14/21 06:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
TIA as always ! bow
beer
I did, the transgo manual shift & set it up to still use the throttle pressure cable, so light throttle it shifts soft, WOT it has full pressure & shifts very firm & I converted my stock shifter to cable & cut & ground slots on the shifter plate so it works like a gated shifter, they do make plates already modified,, 68 Charger, also have 2 switches one for lock up & OD
Re: 70 E-body console with 518 trans and stock type shifter? [Re: CSK] #2953814
08/14/21 06:30 PM
08/14/21 06:30 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
TIA as always ! bow
beer
Is that a full manual + regular pattern?
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BDW] #2953820
08/14/21 06:55 PM
08/14/21 06:55 PM
California
California
Thank you for the link!
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 70 E-body console with 518 trans and stock type shifter? [Re: moparx] #2953821
08/14/21 06:56 PM
08/14/21 06:56 PM
California
California
Mrob & Moparite,
Thank you for the info and the link! Much appreciated.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 70 E-body console with 518 trans and stock type shifter? [Re: BigDaddy440] #2953835
08/14/21 07:37 PM
08/14/21 07:37 PM
Maryland
mrob Offline
mrob  Offline
Maryland
Bigdaddy,
Attached are a few pics from my swap when I was mocking things up and had to fabricate the lower part (pivot) for the linkage.
First pic: Notice how the vertical rod from the shifter is angled to clear the A-518 tailshaft. That's unavoidable because the A-518 tailshaft is so much larger than the A-727.
Second pic: my solution (your's might be different). I used the OEM bracket but modified how it was bolted to the transmission. In my case, I made a new bracket which bolted to some longer transmission pan bolts. The bolts are 5/16 diameter and there are 2 of them, so it's secured well.
Hope this helps
Re: 70 E-body console with 518 trans and stock type shifter? [Re: A39Coronet] #2953855
08/14/21 08:29 PM
08/14/21 08:29 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
TIA as always ! bow
beer
Yes & Yes, converting my stock shifter to a cable was not all that difficult & it works awesome
Re: 70 E-body console with 518 trans and stock type shifter? [Re: moparx] #2953887
08/14/21 10:13 PM
08/14/21 10:13 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
TIA as always ! bow
beer
I started to. But wanted a couple of other changes that the shift kit did not address. So, I had A&A custom build a forward manual valve body. I also had them take some hit out of the 1-2 shift and some pressure out of reverse so that it didn't bang going in with my higher idle RPM. It was more money, of course. But I am very happy with the results.
And I think that the Slap Stick shifter is the best shifter I have ever used. Works great even with the manual valve body.
Master, again and still
Re: 70 E-body console with 518 trans and stock type shifter? [Re: DaveRS23] #2954290
08/16/21 01:40 PM
08/16/21 01:40 PM
moparx Offline
moparx  Offline
Charlie, i thought you had a trans-go shift kit, but i thought it was the TF-2od one. you probably told me at one time you used a TF-3od, but everyone here knows my cobwebs "hide" lots of stuff i "know". biggrin
Dave, i have a junk slapstick here i have been soaking with all kinds of stuff in an attempt to loosen it up from it's rusted solid state. my reason for dinking around with this shifter instead of obtaining a good or better one, is because i want to see if i can fab up the parts necessary to convert my factory shifter in my charger to a slapstick setup. i have a gate plate, maybe a duncan piece, i'm not sure, but i like the way a slapstick works better. i'm keeping my charger a 727 for the [long] foreseeable future.
as for the 518, and the TF-3od kit, my plan for this is for my 33 humpback panel [eternal] project. i want to hook this transmission to a pushbutton shifter. i figure if imperial services can figure this out, so can i. i have several good pushbutton assemblies on the shelf, plus a few junkers i can "practice" on to get the movement right to work with the 518. i also have a bunch of shift leavers for the transmission, plus a bunch of "leftover" levers that i have picked up over the years when my buddies would buy shifters for their ferds and chubbys, and then toss the leftover parts my way.
that's my plan[s], so anything tossed my way i will appreciate ! up
beer
