70 E-body console with 518 trans and stock type shifter?
#2953592
08/13/21 10:14 PM
08/13/21 10:14 PM
Posts: 707 California
BigDaddy440
California
Any vendor make a kit or stock style shifter to use in a factory 70 E-body auto console setup with a 4speed auto like the 518 Trans?
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: 70 E-body console with 518 trans and stock type shifter?
[Re: Jim_Lusk]
#2953630
08/14/21 01:42 AM
08/14/21 01:42 AM
BigDaddy440
California
Thank you guys, that sense!
Hope you're well Jim!
[Re: Moparite]
#2953668
08/14/21 10:13 AM
08/14/21 10:13 AM
Posts: 4,734 Florida
BDW
[Re: moparx]
#2953808
08/14/21 06:05 PM
08/14/21 06:05 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
has anyone swapped to a 518, then modified the valve body with a trans -go TFOD-3 kit, which is supposed to make the 518 a manual valve body ? if so, how did it work out ? how did it work if you used a slapstick shifter ? TIA as always ! I did, the transgo manual shift & set it up to still use the throttle pressure cable, so light throttle it shifts soft, WOT it has full pressure & shifts very firm & I converted my stock shifter to cable & cut & ground slots on the shifter plate so it works like a gated shifter, they do make plates already modified,, 68 Charger, also have 2 switches one for lock up & OD
[Re: CSK]
#2953814
08/14/21 06:30 PM
08/14/21 06:30 PM
Posts: 1,113 Usa
A39Coronet
Usa
has anyone swapped to a 518, then modified the valve body with a trans -go TFOD-3 kit, which is supposed to make the 518 a manual valve body ? if so, how did it work out ? how did it work if you used a slapstick shifter ? TIA as always ! I did, the transgo manual shift & set it up to still use the throttle pressure cable, so light throttle it shifts soft, WOT it has full pressure & shifts very firm & I converted my stock shifter to cable & cut & ground slots on the shifter plate so it works like a gated shifter, they do make plates already modified,, 68 Charger, also have 2 switches one for lock up & OD Is that a full manual + regular pattern?
[Re: moparx]
#2953821
08/14/21 06:56 PM
08/14/21 06:56 PM
BigDaddy440
California
Mrob & Moparite,
Thank you for the info and the link! Much appreciated.
[Re: A39Coronet]
#2953855
08/14/21 08:29 PM
08/14/21 08:29 PM
CSK
Pattison Texas
has anyone swapped to a 518, then modified the valve body with a trans -go TFOD-3 kit, which is supposed to make the 518 a manual valve body ? if so, how did it work out ? how did it work if you used a slapstick shifter ? TIA as always ! I did, the transgo manual shift & set it up to still use the throttle pressure cable, so light throttle it shifts soft, WOT it has full pressure & shifts very firm & I converted my stock shifter to cable & cut & ground slots on the shifter plate so it works like a gated shifter, they do make plates already modified,, 68 Charger, also have 2 switches one for lock up & OD Is that a full manual + regular pattern? Yes & Yes, converting my stock shifter to a cable was not all that difficult & it works awesome
[Re: moparx]
#2953887
08/14/21 10:13 PM
08/14/21 10:13 PM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
has anyone swapped to a 518, then modified the valve body with a trans -go TFOD-3 kit, which is supposed to make the 518 a manual valve body ? if so, how did it work out ? how did it work if you used a slapstick shifter ? TIA as always ! I started to. But wanted a couple of other changes that the shift kit did not address. So, I had A&A custom build a forward manual valve body. I also had them take some hit out of the 1-2 shift and some pressure out of reverse so that it didn't bang going in with my higher idle RPM. It was more money, of course. But I am very happy with the results. And I think that the Slap Stick shifter is the best shifter I have ever used. Works great even with the manual valve body.
Master, again and still
[Re: DaveRS23]
#2954290
08/16/21 01:40 PM
08/16/21 01:40 PM
Posts: 19,464 north of coder
moparx
Charlie, i thought you had a trans-go shift kit, but i thought it was the TF-2od one. you probably told me at one time you used a TF-3od, but everyone here knows my cobwebs "hide" lots of stuff i "know". Dave, i have a junk slapstick here i have been soaking with all kinds of stuff in an attempt to loosen it up from it's rusted solid state. my reason for dinking around with this shifter instead of obtaining a good or better one, is because i want to see if i can fab up the parts necessary to convert my factory shifter in my charger to a slapstick setup. i have a gate plate, maybe a duncan piece, i'm not sure, but i like the way a slapstick works better. i'm keeping my charger a 727 for the [long] foreseeable future. as for the 518, and the TF-3od kit, my plan for this is for my 33 humpback panel [eternal] project. i want to hook this transmission to a pushbutton shifter. i figure if imperial services can figure this out, so can i. i have several good pushbutton assemblies on the shelf, plus a few junkers i can "practice" on to get the movement right to work with the 518. i also have a bunch of shift leavers for the transmission, plus a bunch of "leftover" levers that i have picked up over the years when my buddies would buy shifters for their ferds and chubbys, and then toss the leftover parts my way. that's my plan[s], so anything tossed my way i will appreciate !
