Re: Valvetrain Pre-lube Question; Camshaft Position?
[Re: amxautox]
#29533
09/09/06 09:53 PM
09/09/06 09:53 PM
Posts: 96,659 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
picture 2 showing the hole thru cam
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#29534
09/10/06 12:23 AM
09/10/06 12:23 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
I'd go with what 57 said. With someone running the drill, within 2 crank revolutions, you will find it.
It's pretty obvious when the cam lines up with the empty passage. You'll hear lots of slurping noises. Try it with the oil filler cap off.
[Re: BIGTRUCKNUT]
#29536
09/10/06 09:37 AM
09/10/06 09:37 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Why not just use the starter (with the plugs out)? I use the drill to prefill all the passages and get pressurized oil into the bearings and passages, then drop the distributor shaft in and spin it with the starter until everything's wet. -Charles
[Re: BIGTRUCKNUT]
#29540
02/02/09 08:50 PM
02/02/09 08:50 PM
RapidRobert
After all the turning I take the rocker arms/lifters/pushrods back off & put more lube on the cam then reinstall the above.
