Mercedes fan controller
#2951909
08/08/21 11:29 PM
08/08/21 11:29 PM
Posts: 22 NW Indiana
motorhead446
NW Indiana
Hello, are the fan controllers created by some members here still available? Thanks
66 coronet 500 67 belvedere 70 duster 71 dart
Re: Mercedes fan controller
[Re: moparx]
#2952396
08/10/21 11:09 AM
08/10/21 11:09 AM
Posts: 3,890 Oregon
hooziewhatsit
how would one of these work on a dual fan setup from a 2012 chrysler 300 ? as compared to a derale PWM controler used on the above fan ? My controller only works with the Mercedes fan (or possibly some BMW ones too ). The MB fan has four wires going to it; two large ones for power and ground, and two small signal wires. Most other fan controllers can work with fans that only have the two large power wires, by interrupting the power going through the fan. The MB fan has an onboard computer that takes the PWM signal from my controller, and uses that to control the fan speed. It looks like the dual fan from the 300 only has two power wires to each fan, so it will not work with my controller.
[Re: moparx]
#2952839
08/11/21 03:32 PM
08/11/21 03:32 PM
Posts: 1,883 Northern OH
rapom
Northern OH
Autocoolguy.com
This is the controller you need. I bought a 125amp unit. And he has higher ones.
Look at the feedback on the best ones that Summit sells. A lot of failures.
I also have one of howisits (member here) controller for my Mercedes fan and it works great. It’s probably 8 years old, one of his first ones.
[Re: rapom]
#2952931
08/11/21 07:11 PM
08/11/21 07:11 PM
Posts: 1,893 Harriman NY
71GTX471
Harriman NY
Which MB C class fan assy.203 chassis or 204,or what part#.
Read the original post fans are from the C class W203 chassis 2000/07
[Re: roadrunninMark]
#2953028
08/11/21 11:39 PM
08/11/21 11:39 PM
Posts: 3,890 Oregon
hooziewhatsit
Basically, if the plug looks like this, it will work. There's an 850w fan I know works that I can try to find the part number for. http://ma-uav.com/images/Fan%20Plug%20and%20harness%202.jpgI had come across some other model that did not use that plug, but had two large power wires, and two small signal wires, and would probably work as well.
[Re: motorhead446]
#2953403
08/13/21 11:10 AM
08/13/21 11:10 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's nice to see this is still going strong.
