Fuel filter placement? #2951371
08/07/21 01:21 PM
08/07/21 01:21 PM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
A truck I'm working on for a buddy needs the fuel system replumbed. It has a Holley electric pump and a Fram cartridge filter between the tank and pump. Shouldn't it be after the pump or does it really matter?
Thanks! wave
Re: Fuel filter placement? [Re: slantzilla] #2951374
08/07/21 01:40 PM
08/07/21 01:40 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I always use a filter before the pump and a filter at the carb.
Re: Fuel filter placement? [Re: rickraw] #2951379
08/07/21 01:55 PM
08/07/21 01:55 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Coarse filter between tank & pump, fine filter at/near carb - that's worked fine for me.
At least up to about 640HP & low 10s, and a few hot street cars in the 500-600HP range up to 11.30s.
Re: Fuel filter placement? [Re: slantzilla] #2951393
08/07/21 02:29 PM
08/07/21 02:29 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The paper filter is restrictive.
Re: Fuel filter placement? [Re: slantzilla] #2951481
08/07/21 07:55 PM
08/07/21 07:55 PM
80 to 100+ (bigger number is bigger particles)micron filter between the tank and pump and a 10 micron close to the carb up
Re: Fuel filter placement? [Re: Cab_Burge] #2951561
08/08/21 08:13 AM
08/08/21 08:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can use a 100 micron screen before the pump, but never a cellulose filter. if it were me i'd use a factory type sock in the tank and a 10 micron cellulose up by the carb; simple, effective, and low cost.
Re: Fuel filter placement? [Re: lewtot184] #2951660
08/08/21 01:00 PM
08/08/21 01:00 PM
I've been told all paper type fuel filters are rated at 10 micron shruggy scope
Re: Fuel filter placement? [Re: Cab_Burge] #2952144
08/09/21 06:33 PM
08/09/21 06:33 PM
Park Forest, IL
Park Forest, IL
Thanks for the tips everyone! beer
