Need 67 Barracuda Frame Dimensions ...from SHOP MANUAL #29510
09/09/06 09:27 AM
09/09/06 09:27 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I took the 67 Cuda to the frame alignment shop.
Turned out the big rock that hit the K frame did compromise the front frame rails....but not by much....it doesnt even look that it shited at all in plain sight but when you measure it you can tell it did.....
Anyway....
Ill have the front frame pulled back into shape and after that Ill do the body work and then the full cage....
However I would like to hav ethe frame dimensions chart off the 67 Shop Manual.
Can anybody please post a pic of it???
THanks!
Domingo
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29511
09/09/06 04:51 PM
09/09/06 04:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I hauled my 71 4 door Dart to the shop this morning so it can donate all of it's front suspension to the Barracuda....
The 4 door is mint, so I can probably use trhat car for the frame dimensions...
However it'd be nice to have the unibody dimensions for the 67 cuda....
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29512
09/10/06 01:25 PM
09/10/06 01:25 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29513
09/10/06 02:43 PM
09/10/06 02:43 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 67 Barracuda stuff is in an addendum to the 1967 FSM, but it does not show the frame measurements.
Barry
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: Alaskan_TA] #29514
09/10/06 03:13 PM
09/10/06 03:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK well, I guess any 67-76?? A Body Frame measurements would work???
They are the exact same platform over the years...right?
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29515
09/10/06 07:24 PM
09/10/06 07:24 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
last try...
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29516
09/10/06 11:29 PM
09/10/06 11:29 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
As long as they're 108" wheelbase, they're the same. I've got the crash sheets for my 67 Barracuda somewhere, but I don't have a scanner to scan it any more. I've also got a digital image somewhere, too, but it's been archived, and I've got a bunch of disks to search. I'll try to find it and post it in the next day or so.
Clair
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: Clair_Davis] #29517
09/11/06 01:25 AM
09/11/06 01:25 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
That would be great Clair!
The sooner the better though since they will start working on my car tomorrow morning and they told me to bring the chart with me....I told them I could get it for Monday!!!
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29518
09/11/06 09:40 AM
09/11/06 09:40 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
maybe somebody else has it to post right away? If not lets wait for Clair...
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29519
09/11/06 10:09 PM
09/11/06 10:09 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
WARNING DIAL-UP USERS!!! 860KB JPEG IMAGE ATTACHED!!
These are the frame specs for all 67-69 Valiants and Barracudas. Hope everything comes out nice and square!
Clair
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: Clair_Davis] #29520
09/11/06 11:22 PM
09/11/06 11:22 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29521
09/11/06 11:30 PM
09/11/06 11:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Will post again in this thread in a couple days to let you know how it turned out...
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: Clair_Davis] #29522
09/12/06 07:20 AM
09/12/06 07:20 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Do you happen to have Dart specs by chance? I was looking for this a while back and could not find it. This would be perfect!
Thanks,
-Rob
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: njmopar] #29523
09/12/06 09:17 AM
09/12/06 09:17 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I would bet the dart dimansions are exactly the same....I think both cars have the same wheelbase...and we all know that the subframes and all that are the exact same...
Re: Need 67 Barracuda Frame Dimensions Chart....HELP!!! [Re: domingo] #29524
09/12/06 03:12 PM
09/12/06 03:12 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
67-76 Darts (except Dart Sport/Demon) had 111" wheelbases, Barracudas and Valiants (2-door post, 4-door) had 108". I don't have the sheets for any Dodges, but I do have the earlier Barracudas, and 67-68 Furys.
Clair
Re: Need 67 Barracuda Frame Dimensions ...from SHOP MANUAL [Re: domingo] #29525
09/12/06 05:57 PM
09/12/06 05:57 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Will this work?
Re: Need 67 Barracuda Frame Dimensions ...from SHOP MANUAL [Re: farmboy70] #29526
09/12/06 06:01 PM
09/12/06 06:01 PM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
I guess I should have read the whole post,if anyone needs 1970 or 1971 charts I can post them,all body styles.
