Backfire Under Deceleration #2949831
08/02/21 09:57 PM
08/02/21 09:57 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Can someone give me some ideas on how to chase down a problem with my car backfiring through the exhaust when I let off the gas? It's a 440 with a Holley chokeless main body carb and QFT metering blocks and bowls.
I thought it might be an exhaust leak at the collector gaskets, but I replaced them both to no change.
Assuming no exhaust leak, it would have to be carb related, right?
Thank you.
Greg
Re: Backfire Under Deceleration [Re: GregY] #2949832
08/02/21 10:03 PM
08/02/21 10:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
to lean on decel will cause it to do that, if you are saying it pops out of the exhaust
Re: Backfire Under Deceleration [Re: GregY] #2949887
08/03/21 01:24 AM
08/03/21 01:24 AM
Every popping when let of I've work on and helped people solve has ended up being outside air suck into the exhaust shruggy
Gaskets, cracks, bent flanges and so on scope up
Re: Backfire Under Deceleration [Re: Cab_Burge] #2949913
08/03/21 07:46 AM
08/03/21 07:46 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
My experience, too rich on deceleration (high vacuum pulling excessive fuel through the idle circuit) and exhaust leaks.
Try leaning your idle and plug your tailpipes to find the leaks.
Angry white pureblood male
Re: Backfire Under Deceleration [Re: ruderunner] #2949977
08/03/21 11:42 AM
08/03/21 11:42 AM
Washington
madscientist Offline
Washington
Rude runner nailed it. It’s pig rich at idle and cruise and then on decel all that fuel goes off late and causes the back fire. I have never, even seen a header leak cause a backfire unless it pig rich.
Re: Backfire Under Deceleration [Re: madscientist] #2949980
08/03/21 11:59 AM
08/03/21 11:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Seen that happen with an intake manifold leak.
Re: Backfire Under Deceleration [Re: 6PakBee] #2950032
08/03/21 02:41 PM
08/03/21 02:41 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Okay, thanks everyone. I think I will pursue it initially as being too rich and go from there.
Re: Backfire Under Deceleration [Re: GregY] #2950110
08/03/21 06:34 PM
08/03/21 06:34 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Tooooo lean can also cause this condition, my HD did it until I upped the pilot jet 1 size.
Re: Backfire Under Deceleration [Re: 71GTX471] #2950277
08/04/21 06:25 AM
08/04/21 06:25 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Backfire in the exhaust is from unburned fuel in the pipe. Yes, it can be from too lean but you'd probably have misfires and generally crappy running if that lean.
On a Harley, you'd never notice the poor performance.
Re: Backfire Under Deceleration [Re: 6PakBee] #2950278
08/04/21 06:27 AM
08/04/21 06:27 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
And I bet the carb was dialed in rich to cover the vacuum leak.
Re: Backfire Under Deceleration [Re: ruderunner] #2950340
08/04/21 10:39 AM
08/04/21 10:39 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Could have been. IIRC, it was from the valley side and was discovered by the oil tracks when the intake was removed for a camshaft change. But it's been a long time ago and the memory gets fuzzy.
