Re: Backfire Under Deceleration
[Re: GregY]
#2949832
08/02/21 10:03 PM
08/02/21 10:03 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
to lean on decel will cause it to do that, if you are saying it pops out of the exhaust
[Re: Cab_Burge]
#2949913
08/03/21 07:46 AM
08/03/21 07:46 AM
Posts: 5,846 ohio
ruderunner
ohio
My experience, too rich on deceleration (high vacuum pulling excessive fuel through the idle circuit) and exhaust leaks.
Try leaning your idle and plug your tailpipes to find the leaks.
Angry white pureblood male
[Re: ruderunner]
#2949977
08/03/21 11:42 AM
08/03/21 11:42 AM
Posts: 4,457 Washington
madscientist
Washington
Rude runner nailed it. It’s pig rich at idle and cruise and then on decel all that fuel goes off late and causes the back fire. I have never, even seen a header leak cause a backfire unless it pig rich.
[Re: madscientist]
#2949980
08/03/21 11:59 AM
08/03/21 11:59 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Seen that happen with an intake manifold leak.
[Re: 71GTX471]
#2950277
08/04/21 06:25 AM
08/04/21 06:25 AM
Posts: 5,846 ohio
ruderunner
ohio
Backfire in the exhaust is from unburned fuel in the pipe. Yes, it can be from too lean but you'd probably have misfires and generally crappy running if that lean.
On a Harley, you'd never notice the poor performance.
[Re: 6PakBee]
#2950278
08/04/21 06:27 AM
08/04/21 06:27 AM
Posts: 5,846 ohio
ruderunner
ohio
Seen that happen with an intake manifold leak. And I bet the carb was dialed in rich to cover the vacuum leak.
[Re: ruderunner]
#2950340
08/04/21 10:39 AM
08/04/21 10:39 AM
6PakBee
North Dakota
Seen that happen with an intake manifold leak. And I bet the carb was dialed in rich to cover the vacuum leak. Could have been. IIRC, it was from the valley side and was discovered by the oil tracks when the intake was removed for a camshaft change. But it's been a long time ago and the memory gets fuzzy.
