904 SPRAG DAMAGED ?????? #2949601
08/02/21 08:55 AM
08/02/21 08:55 AM
MD
1965fish Offline OP
1965fish  Offline OP
MD
I broke a gearset this weekend.
It left normal. 1.42 60 foot.
On the second gear shift the gearset let go.
My question is.
Do I have to pull the trans and check the sprag like you would have to in a 727????
Thanks for any advice.
1965 Plymouth Barracuda Formula S
1965 Plymouth Valiant 200 Convertible
1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104
2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile
1965 Plymouth Valiant Signet 2DR HT
Re: 904 SPRAG DAMAGED ?????? [Re: 1965fish] #2949680
08/02/21 12:57 PM
08/02/21 12:57 PM
My question is.
Are you feeling lucky? Do you want to hope it is not damaged or do you want to know work wrench scope twocents
Re: 904 SPRAG DAMAGED ?????? [Re: Cab_Burge] #2949684
08/02/21 01:04 PM
08/02/21 01:04 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I would pull it and for the cost of a pump gasket and tail shaft gasket you would know. Also you get to give the trans a physical if its been a while.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: 904 SPRAG DAMAGED ?????? [Re: Cab_Burge] #2949685
08/02/21 01:09 PM
08/02/21 01:09 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
YES!
Even if it still seems fine to drive.
Last one I fixed, the guy was driving it around on the street after busting the rear at the track. I convinced him to pull it and let me look at it, before he took it to the track again. Half the springs were crushed, rollers loose, half were actually still functioning enough to drive the car. It would not have survived the first hit.
Re: 904 SPRAG DAMAGED ?????? [Re: CMcAllister] #2949751
08/02/21 05:44 PM
08/02/21 05:44 PM
Locomotion Offline
Locomotion  Offline
Originally Posted by CMcAllister
YES!
In 2017 I broke a ring & pinion at a test & tune before an important double header weekend. Spent Day 1 putting in a new gear and won on Day 2! First pass at a T&T at the next event I went to, the 904 sprag "finished breaking"!
OP did say that it happened on the 1-2 shift. I don't know if that would make any difference, but I wouldn't risk it. .
Re: 904 SPRAG DAMAGED ?????? [Re: CMcAllister] #2949754
08/02/21 05:50 PM
08/02/21 05:50 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
X2. Friend of mine had same issue. Drove fine. When I disassembled his trans the outer race split the case.
Re: 904 SPRAG DAMAGED ?????? [Re: rickraw] #2949782
08/02/21 07:21 PM
08/02/21 07:21 PM
CA
crackedback Offline
crackedback  Offline
CA
Take it apart and check. At least the drum isn't like a 727 waiting to explode.
Nice thing about a 904, the sprag being out won't put the drum in danger unless you have a real high winding engine (most never get close to critical mass RPM).
Re: 904 SPRAG DAMAGED ?????? [Re: rickraw] #2949783
08/02/21 07:21 PM
08/02/21 07:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In theory, if the 1-2 shift was completed, the sprag should be out of play but ...............
Re: 904 SPRAG DAMAGED ?????? [Re: John_Kunkel] #2949810
08/02/21 08:49 PM
08/02/21 08:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If the roller clutch was under load when the driveline freewheeled, it's hurt. 1-2 shift point would have been up there in the revs.
Re: 904 SPRAG DAMAGED ?????? [Re: 1965fish] #2949898
08/03/21 05:53 AM
08/03/21 05:53 AM
MD
1965fish Offline OP
1965fish  Offline OP
MD
Thank you guys for all of the input.
Pulling the trans later today and putting in my new spare.
Hopefully back racing this weekend.
Re: 904 SPRAG DAMAGED ?????? [Re: 1965fish] #2950009
08/03/21 01:49 PM
08/03/21 01:49 PM
moparx Offline
moparx  Offline
please let us know what you find.
beer
Re: 904 SPRAG DAMAGED ?????? [Re: moparx] #2951934
08/09/21 05:24 AM
08/09/21 05:24 AM
MD
1965fish Offline OP
1965fish  Offline OP
MD
Pulled the trans apart yesterday.
Everything checked out fine.
I guess my rear end issue may have been different than a normal ring and pinion break.
It spit the side adjuster out which made the ring disengage from the pinion gear;
so it just freewheeled and did not disengage then engage again like when knocking off teeth.
It just free wheeled like throwing into neutral.
Going to put it back in this weekend.
Re: 904 SPRAG DAMAGED ?????? [Re: 1965fish] #2952429
08/10/21 12:23 PM
08/10/21 12:23 PM
moparx Offline
moparx  Offline
thanks for the update. glad the transmission was ok, but too bad about the rear.
beer
