904 SPRAG DAMAGED ??????
#2949601
08/02/21 08:55 AM
08/02/21 08:55 AM
Posts: 39 MD
1965fish
MD
I broke a gearset this weekend. It left normal. 1.42 60 foot. On the second gear shift the gearset let go. My question is. Do I have to pull the trans and check the sprag like you would have to in a 727????
Thanks for any advice.
1965 Plymouth Barracuda Formula S 1965 Plymouth Valiant 200 Convertible 1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104 2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile 1965 Plymouth Valiant Signet 2DR HT
Re: 904 SPRAG DAMAGED ??????
[Re: Cab_Burge]
#2949685
08/02/21 01:09 PM
08/02/21 01:09 PM
Posts: 11,652 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
YES!
Even if it still seems fine to drive.
Last one I fixed, the guy was driving it around on the street after busting the rear at the track. I convinced him to pull it and let me look at it, before he took it to the track again. Half the springs were crushed, rollers loose, half were actually still functioning enough to drive the car. It would not have survived the first hit.
[Re: CMcAllister]
#2949751
08/02/21 05:44 PM
08/02/21 05:44 PM
Posts: 5,894 Florida
Locomotion
YES!
In 2017 I broke a ring & pinion at a test & tune before an important double header weekend. Spent Day 1 putting in a new gear and won on Day 2! First pass at a T&T at the next event I went to, the 904 sprag " finished breaking"! OP did say that it happened on the 1-2 shift. I don't know if that would make any difference, but I wouldn't risk it. .
[Re: rickraw]
#2949783
08/02/21 07:21 PM
08/02/21 07:21 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In theory, if the 1-2 shift was completed, the sprag should be out of play but ...............
[Re: John_Kunkel]
#2949810
08/02/21 08:49 PM
08/02/21 08:49 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If the roller clutch was under load when the driveline freewheeled, it's hurt. 1-2 shift point would have been up there in the revs.
[Re: 1965fish]
#2949898
08/03/21 05:53 AM
08/03/21 05:53 AM
Posts: 39 MD
1965fish
MD
Thank you guys for all of the input.
Pulling the trans later today and putting in my new spare.
Hopefully back racing this weekend.
[Re: moparx]
#2951934
08/09/21 05:24 AM
08/09/21 05:24 AM
Posts: 39 MD
1965fish
MD
Pulled the trans apart yesterday. Everything checked out fine. I guess my rear end issue may have been different than a normal ring and pinion break. It spit the side adjuster out which made the ring disengage from the pinion gear; so it just freewheeled and did not disengage then engage again like when knocking off teeth. It just free wheeled like throwing into neutral. Going to put it back in this weekend.
