Re: truck oil pan Big Block
[Re: modelmakerinc]
#2947280
07/26/21 11:37 AM
07/26/21 11:37 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
so if the dipstick goes to the side of the pan, what was used for the hole in the block, some type of plug? Yep. A little bitty freeze plug looking plug.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: modelmakerinc]
#2949288
08/01/21 01:00 AM
08/01/21 01:00 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
fellas, I see some big block truck pans have a brass elbow and different dipstick down in the sump and others dont. what is the application for these? RV?, 2x4? 4x4?, different years? what is the straight poop on this Thanks in advance Henry The only motors I've seen them in is Class A motorhomes ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) All the pickup truck and van motors I've seen had the longer standard drive in dipstick tubes and dipsticks, not with the elbows ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: 440_Offroader]
#2949457
08/01/21 04:57 PM
08/01/21 04:57 PM
Posts: 16,840 Between Houston & Galveston TX
SattyNoCar
I've had a 76 Ramcharger and a 78 W150. Both trucks had factory 400 engines. They both had the dipstick tube run to the pan with the 90 degree fitting. Actually, every factory rear sump big block pan that I've seen, has that fitting. I'm not saying that that's always true, just what I've seen with 70's trucks engines I've worked with. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Matter of fact, way back when I was dealing with this issue, the truck pan didn't have a provision for the block mounted dipstick. I was swapping a 440 in place of a 360 using a wrecked 400 equipped truck for parts.
John
[Re: modelmakerinc]
#2951975
08/09/21 09:53 AM
08/09/21 09:53 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I've only seen 72 up trucks & some RV's have these.
Some of the 71 & down trucks & RV's had a front sump pans also.
Moparlee
[Re: moparmarks]
#2951977
08/09/21 09:57 AM
08/09/21 09:57 AM
Robbins
Joplin, MO USA
71 and back have a front sump pan. Lower pan Class A motorhome have a deeper front sump pan. Upper pan Nice....I haven't seen a front sump with the dip stick in it...cool stuff.
Moparlee
[Re: Robbins]
#2952057
08/09/21 02:11 PM
08/09/21 02:11 PM
moparmarks
Actually the upper motorhome pan has a plug in the side. It did not have a dip stick there and not really sure what it is for. It is a larger size than the dip stick fitting.
[Re: moparmarks]
#2952269
08/09/21 10:47 PM
08/09/21 10:47 PM
Posts: 10,634 Freeport IL USA
poorboy
Freeport IL USA
Actually the upper motorhome pan has a plug in the side. It did not have a dip stick there and not really sure what it is for. It is a larger size than the dip stick fitting. Could have been a fitting for an oil temp gauge.
[Re: Cab_Burge]
#2952300
08/10/21 02:03 AM
08/10/21 02:03 AM
Posts: 31,074 Oregon
AndyF
fellas, I see some big block truck pans have a brass elbow and different dipstick down in the sump and others dont. what is the application for these? RV?, 2x4? 4x4?, different years? what is the straight poop on this Thanks in advance Henry The only motors I've seen them in is Class A motorhomes ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) All the pickup truck and van motors I've seen had the longer standard drive in dipstick tubes and dipsticks, not with the elbows You have your oil pans mixed up Cab. The light truck pans have a rear sump and the dipstick goes into the sump using a brass fitting. The dipstick hole in the block is plugged with a small aluminum plug.
[Re: modelmakerinc]
#2952301
08/10/21 02:05 AM
08/10/21 02:05 AM
AndyF
fellas, I see some big block truck pans have a brass elbow and different dipstick down in the sump and others dont. what is the application for these? RV?, 2x4? 4x4?, different years? what is the straight poop on this Thanks in advance Henry The truck pan was a popular package from Mopar Performance for years. I think it is disco now but it used to be a nice deal complete with the pickup tube. I bought and sold lots of those pans over the years. Just sold my last one for $20 to a drag racer who needed a core to build a rear sump pan for his drag car. He cut the sump off and built his own.
[Re: moparmarks]
#2952351
08/10/21 09:39 AM
08/10/21 09:39 AM
Robbins
Joplin, MO USA
Actually the upper motorhome pan has a plug in the side. It did not have a dip stick there and not really sure what it is for. It is a larger size than the dip stick fitting. Right on.
Moparlee
[Re: moparmarks]
#2952463
08/10/21 01:34 PM
08/10/21 01:34 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Actually the upper motorhome pan has a plug in the side. It did not have a dip stick there and not really sure what it is for. It is a larger size than the dip stick fitting. That was for an air compressor return line and I think some also had a big oil cooler that also used the return to pan fitting. I had a C800 With the 413 that used that return port.
