truck oil pan Big Block #2947218
07/26/21 07:27 AM
07/26/21 07:27 AM
west palm beach, florida
modelmakerinc Offline OP
fellas, I see some big block truck pans have a brass elbow and different dipstick down in the sump and others dont. what is the application for these? RV?, 2x4? 4x4?, different years? what is the straight poop on this Thanks in advance Henry
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: truck oil pan Big Block [Re: modelmakerinc] #2947255
07/26/21 10:27 AM
07/26/21 10:27 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
The rear sump pan with the dipstick on the side is from 1972-78 Pickup both 2wd and 4wd. Can also use from big block conversion on 1979-93.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: truck oil pan Big Block [Re: moparmarks] #2947267
07/26/21 11:08 AM
07/26/21 11:08 AM
so if the dipstick goes to the side of the pan, what was used for the hole in the block, some type of plug?
Re: truck oil pan Big Block [Re: modelmakerinc] #2947280
07/26/21 11:37 AM
07/26/21 11:37 AM
moparmarks Offline
moparmarks  Offline
Yep. A little bitty freeze plug looking plug.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: truck oil pan Big Block [Re: modelmakerinc] #2949288
08/01/21 01:00 AM
08/01/21 01:00 AM
The only motors I've seen them in is Class A motorhomes shruggy
All the pickup truck and van motors I've seen had the longer standard drive in dipstick tubes and dipsticks, not with the elbows shruggy
Re: truck oil pan Big Block [Re: Cab_Burge] #2949347
08/01/21 10:42 AM
08/01/21 10:42 AM
Alberta
440_Offroader Offline
Alberta
I've had a 76 Ramcharger and a 78 W150. Both trucks had factory 400 engines. They both had the dipstick tube run to the pan with the 90 degree fitting. Actually, every factory rear sump big block pan that I've seen, has that fitting. I'm not saying that that's always true, just what I've seen with 70's trucks engines I've worked with.
Re: truck oil pan Big Block [Re: 440_Offroader] #2949457
08/01/21 04:57 PM
08/01/21 04:57 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
iagree
Matter of fact, way back when I was dealing with this issue, the truck pan didn't have a provision for the block mounted dipstick. I was swapping a 440 in place of a 360 using a wrecked 400 equipped truck for parts.
John
Re: truck oil pan Big Block [Re: SattyNoCar] #2949506
08/01/21 07:31 PM
08/01/21 07:31 PM
moparmarks Offline
moparmarks  Offline
72-78 D/W rear sump oil pan
I have owned several 72-78 BB truck and they all pan this pan
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: truck oil pan Big Block [Re: moparmarks] #2949509
08/01/21 07:33 PM
08/01/21 07:33 PM
moparmarks Offline
moparmarks  Offline
71 and back have a front sump pan. Lower pan
Class A motorhome have a deeper front sump pan. Upper pan
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: truck oil pan Big Block [Re: moparmarks] #2949561
08/01/21 10:33 PM
08/01/21 10:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That is what they had along with the brass 90 degree fitting for the tube to attach to the pan.
Re: truck oil pan Big Block [Re: modelmakerinc] #2951975
08/09/21 09:53 AM
08/09/21 09:53 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I've only seen 72 up trucks & some RV's have these.
Some of the 71 & down trucks & RV's had a front sump pans also.
Moparlee
Re: truck oil pan Big Block [Re: moparmarks] #2951977
08/09/21 09:57 AM
08/09/21 09:57 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Nice....I haven't seen a front sump with the dip stick in it...cool stuff.
Moparlee
Re: truck oil pan Big Block [Re: Robbins] #2952057
08/09/21 02:11 PM
08/09/21 02:11 PM
moparmarks Offline
moparmarks  Offline
Actually the upper motorhome pan has a plug in the side. It did not have a dip stick there and not really sure what it is for. It is a larger size than the dip stick fitting.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: truck oil pan Big Block [Re: moparmarks] #2952269
08/09/21 10:47 PM
08/09/21 10:47 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Could have been a fitting for an oil temp gauge.
Re: truck oil pan Big Block [Re: Cab_Burge] #2952300
08/10/21 02:03 AM
08/10/21 02:03 AM
AndyF Offline
AndyF  Offline
You have your oil pans mixed up Cab. The light truck pans have a rear sump and the dipstick goes into the sump using a brass fitting. The dipstick hole in the block is plugged with a small aluminum plug.
Re: truck oil pan Big Block [Re: modelmakerinc] #2952301
08/10/21 02:05 AM
08/10/21 02:05 AM
AndyF Offline
AndyF  Offline
The truck pan was a popular package from Mopar Performance for years. I think it is disco now but it used to be a nice deal complete with the pickup tube. I bought and sold lots of those pans over the years. Just sold my last one for $20 to a drag racer who needed a core to build a rear sump pan for his drag car. He cut the sump off and built his own.
Re: truck oil pan Big Block [Re: moparmarks] #2952351
08/10/21 09:39 AM
08/10/21 09:39 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Right on.
Moparlee
Re: truck oil pan Big Block [Re: poorboy] #2952387
08/10/21 10:55 AM
08/10/21 10:55 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
I have a front sump out in the shop that has a low oil sensor in the side of it. twocents
Re: truck oil pan Big Block [Re: moparmarks] #2952463
08/10/21 01:34 PM
08/10/21 01:34 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That was for an air compressor return line and I think some also had a big oil cooler that also used the return to pan fitting. I had a C800 With the 413 that used that return port.
Re: truck oil pan Big Block [Re: Hugh Jorgan] #2952496
08/10/21 03:28 PM
08/10/21 03:28 PM
moparmarks Offline
moparmarks  Offline
I think I've seen that before.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
