Re: Last thread for today.. when a belt flips
[Re: Sammy]
#2947042
07/25/21 04:38 PM
07/25/21 04:38 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Clanton]
#2947055
07/25/21 06:11 PM
07/25/21 06:11 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Are you sure nothing is flexing[bracket]? Can you repeat it without driving the car looking at the belts? I agree you will need new belts anyways. Going to double check the alternator spacer. It might be flexing. Not sure. Vacuum pump definitely not flexing and with the wide crank pulley, it basically self aligns and the belt is almost centered on the pulley.
[Re: Dragula]
#2947058
07/25/21 06:13 PM
07/25/21 06:13 PM
Sammy
Wind Gap,Pa.
Its usually a mis-alignment issue or a flexing issue....I would string it with the belt off and see what it looks like. Thanks... going to string it tomorrow. Have to order new belts anyway. Vacuum pump belt has to go on 1st. I do have a spare alternator belt. Always need spares.
[Re: Sammy]
#2947086
07/25/21 07:32 PM
07/25/21 07:32 PM
Posts: 1,030 ohio
67mprfan
ohio
Just went through this on my car, I have a post on B-Bodies only I thought my alignment was good until I put a straight edge on it now everything seems good. I went through 4 belts usually once they flip I changed them out
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
